I’m just saying if Google Play Services is installed then it’s not a conspiracy, it’s a fact. Want to know more? Just read a little from them about the Data they collect. They’re not shy letting you know if you take the time to read. They know most won’t and I’m not trying to convince anyone. It’s pretty much common knowledge or at least I thought it was.
You need to read deeper than you have. To the very location of where the play protect module is installed and precisely why and how the disable is installed and what modules are affected and why. In short this bores me and your saying it is so doesn’t make it so. If it were, then those with an active play protect and app scanning who can’t install a suppose bad app would not simply be able to disable the two modules and then install that very app, not to mention that anyone with an Android system would not be able to install those apps forbidden by google and use them without restriction, and further if they do know that I have 3rd party apps they block and consider what, illegal, they would then do nothing when I am using those very apps? Again I reiterate, OP disable “Improve harmful app detection” and “Scan apps with Play Protect”, by going to the google play store, highlight your Avitar on the top right, click down twice to highlight “Play Protect” on the left, then click right to highlight your two choices on the right and using the “radio” button deselect the modules in the order I mentioned, back out of the Play Store and enjoy your device.
Google is much more interested in their ad revenue than whether I’ve installed a 3rd party supposed malware ridden app. There’s enough in the Play Store as it is.
See this is why I said I’m out. This is all way off topic, and I mean way. So I’m absolutely out. My apologies to the OP.
Bro, I agree with you and I think you’ve misunderstood what I have said or perhaps I misspoke a bit. You can side load any app and if you’re internet is connected and Google flags it as malware it’ll still allow you to install it anyway. I said in my first comment that it’s never happened to me because that’s exactly what I do by default is turn Play protect off. That doesn’t mean they don’t scan still because I will sometimes get “Remove harmful app” warning even with both switches disabled and it gets annoying but it won’t disable it on its own after it’s been turned off. I was merely suggesting the possibility that, for whatever reason, according from multiple posts I’ve read from various people that it does continue to disable the app sometimes. Whether they’re valid Post or just people that don’t know what they’re doing I can’t say. Sorry if it seemed I was undermining you or anyone else because that wasn’t my intentions and I sincerely apologize if it came out that way.
What I stated is fact, as I know it, and have yet to see any definitive links, or info, to disuade me from my assertion you are incorrect in any suggestion that my 3rd party apps are being scanned by play protect in any manner on my device.
Please just Stop. Google is not deleting any apps You keep saying it’s something you read somewhere else but it’s not happening. Stop the nonsense
Don’t bite gentlemen, just let him know he’s incorrect and be gone with it. Unless you’re really bored! LOL ![]()
I installed the proper Flixvision version 32 bit and was hoping to watch Burkes Law from the 60’s but I get an error code 22011. Tried everything to get past that error code. Any sugestions. Thanks
just tried it works fine i would delete your app an down load from troys also latest version is 2.9.0
Not really but I do have the latest 32 bit version I made a couple of changes to for myself because it has an absurd amount of unnecessary permissions. Aside from that I just changed the target SDK from 28 to 33 which prevents Google from flagging it as malware. I also changed the install location to prefer external so it runs better when it’s installed on an external USB drive but that doesn’t make a difference if you don’t. It just helps if you do. I’ll send it to you if you’d like. Just let me know.
I have no idea about SDK except it seems to be associated with an external drive which I have onlt my 4k firestick. I can play other tv shows but for some reason Burkes Law gives me the error code 232011
Software Development Kit. A set of tools for developers.
Do you have a fire stick4K, That is what I am trying to play it on, Burkes law. All the other stuff I can play. Maybe it is a problem with the files
Sorry ya lost me now. Do you have flix vision installed but can’t get and play Burke’s Law?
FYI the 3 seasons are in Stremio '63-'65
Yes. I use a 4K Firestick, I can play all the other stuff but not Burkes Law. Maybe it can’t be played. Everything else works fine. Stremio, is it an apk I can get? I found Stremio. 1.6.7 or 1.6.9 ?
Using the site search will give you a lot of help.
For some unknown reason it would not download. I will again try later on.
After about 2hrs of life wasted, I finally got it to load up and let me sign in as I already have a Malwarebytes account.
Can you send it to me please
