Thanks, I’ll try that.
I just uninstalled my Flix F. It was showing crazy RD links that weren’t even for the advertised Movie I was wanting, every RD link had a commercial at the beginning for Gambling. After this last update it was a disaster. So gone.
What does it mean when it says, “Direct Stream”? Do I need to worry that someone is watching? I do use Surfshark but I’m a little leery. Are those torrent sites?
I’m watching FlixVision now, works perfectly for me but I don’t subscribe to RD. Stremio remains my main Go-To app and RD is not necessary on it, either. FlixVision is merely a backup for Stremio.
Hey Big Dave, I used to use stremio without Rd also but it got the point where I was getting a lot of buffering losing the channel or just won’t at all pick up the stream. I went ahead and got a subscription to Rd integrated now I don’t have any issues with stremio!
I had those buffering problems until I changed the Wi-Fi channels on my modem/router. Now it only buffers for a minute once in a while on start up then plays great! Also, I don’t use Crypto currency, bitcoin, pesos or Rubles ![]()
Ya it was my backup to until this last update messed up the Movies on mine. All good though, lots of choices these days.
I have downloaded Flixvision on my Minix TV Box and all is well but if I shur down my box it loses the app on booting up?
Ant suggestions?
Thanks Alan
You must must must…turn off play protect
Any one having a problem with this app starting a stream , stopping, and then starting from the beginning again
hi playing ok on a stick there has been an update so make sure you have that
Mine played a movie for several minutes and then stopped and either froze or reverted back to home page. Mecool KM6 deluxe. Tried VLC player. Working great!
I sideloaded flixVision on my android tv. 3 days later I received a “malicious software” message from Sony, and they deleted all trace of the app.
Turns out the app wasn’t that good, as many free links were duds. The IPTV section featured 16,000+ channels but drew a blank trying to fins TSN, one of Canada’s premier sports broadcasters.
Most of us turn Google Play Protect off and choose to use apps like Malwarebytes to scan installed apps for security.
I noticed Play Protect being disabled in previous posts, but once it is installed, is FlixVision safe to use?
I upgraded Flix yesterday and all is well. No ads, no buffer
I tried to install Flix Vision after reading the last email from Troy. I get a “this file contains a virus” error. I did not install the apk.
Anyone else seeing that message?
