Where exactly do I find that setting?
Give me a sec and I’ double check to refresh my memory and nozt mess you up. Brb.
From your home screen open your apps and click on Google Play Store, then on the top right highlight your Avatar, and on the left you will see Play Protect, highlight it, then on the right deselect both options. Done
Done, Miki. You are the Best! Thank You.
Now, back to TP to reinstall it.
I got it using the downloader code 108545. Thanks for your reply
Thanks BigDave, most appreciated. For some reason I use Real Debrid but it does not seem to be working, it was okay when I first installed FlixVision but appears it went on vacation without vacation pay. lol. I realinstalled it but still no go for Realdebrid
Just a quick update to my Guardian Angle and a Thank You.
I got it installed!!!
Adult channels isn’t working
Uninstall and reinstall. Button the Adult section and it should come up and have you create a code. Once done it should work fine. (I had to do this to get it to work.)
Was working for me, but today it isn’t. Oops.
These APK’s sure seem to come and go fast. That is why I don’t bother with them
I agree I just add them to test for others and do a deep dive into the settings so I can answer questions. I rarely ever keep them. Just added Plex again and may pay for lifetime.
What does Plex give you that Stremio doesn’t have?
Oh I haven’t a clue @MarkxG , I just put it back on my Tablet after completely wiping it off the Shield Pro a long time ago. There’s supposed to be a new update and new features. I just put it on yesterday and with moving I haven’t had a lot of time to give it a workout.
Sounds like Google Play Protect, They try and discourage you from downloading apps like that. You need to go to Google Play Store and turn off play protect.
I’ve installed FlixVision twice on my Nvidia Shield. Getting past the message that it’s bad, it installs and works fine. BUT, I get out of my Shield and go back later, it’s gone! As I said in the beginning, I’ve installed it twice with the same result. Am I doing something wrong? It seems to be a pretty good app.
Thanks
You have to turn Play Protect off.
GIF tx shout out to PF.
Thanks, I’ll give that a shot.
