Yes new 16GB model. Everything working as it should. The menu is working fine. These guys are updating this app and it appears another update was issued over the weekend. No problem on my new stick whatsoever.
OK, thanks. I’m going to do a factory reset (what a pain!) and will update.
I did working okay
From your comment it seems to me that until something better comes out it’s probably best to not install Flix Vision?
I use TiviMate for TV and StartUp Show for Movies & Series. I would rather have everything in one place but those both work fantastic for me.
By the way I also have Nvidia Shield Pro.
Not sure where you got that from, Flix F Vision is a good app for Adult, VOD, Movies, and series. Like any free live TV it sucks. I have TiViMate for my IPTV. But I installed flix on my Shield Pro as a backup, replacing my OnStream.
OK, so did yet another uninstall/re-install and, no difference. Reset my FireTV 4k Max to factory specs, re-installed Flixvision and… Same - no response to clicking on the left side menu bar.
Loaded up FlixVision this morning to try it again (desperation) and, what’s this… update available. Updated from 2.6.0r to 2.6.2r and BINGO - all working now!
So, I don’t know what the deal is - 2.3, 2.4, 2.6 didn’t work on my OS8 device but 2.6.2 does. Go figure!
It may simply be that the dev missed adding some Fire OS 8 functions and did so in an update. My update is 2.6.2r
Well, it worked fine on my other devices, just this one 4k Max OS8 device had the issue. And that appears to have been resolved with the 2.6.2r update(?)
Having said that, FlixVision isn’t a substitute for Live TV apps (eg TiviMate), just the other stand alone movie/TV show app (like Cinema, BeeTV, FilmPlus, if you don’t have Real Debrid and Surfshark (Cleanweb).
Just got around to trying this app today…Cool layout ![]()
Other than the live TV it works great. I tried the classic layout and prefer the modern. I also like the PIN for adult. MX Player Pro and RD integrated perfectly. Search is ok. FF, RW etc. work great. Replaced my OnStream. I set it for RD sources only. Had glitching with 4K and it doesn’t seem to activate the Shield AI upscaling and that’s odd, but I give it a solid 8 out of 10.
On stream has been having problems lately I quit using it also. You can’t integrate Rd with it. I had issues with stremio also until I integrate with Rd now it’s working fine.
Flexvision has been working great for me past 4 months
I didn’t install a player or debrid simply input the code in the URL on downloader type Flixvision.app that’s it!!
There is an update but it won’t update. Is there a way around that. Plus I seem to not finish any TV show I am watching.
I had the same problem a while back. Solved it by deleting the old version and downloading/installing the latest version from the website flixvision.app
Everything is working fine now.
DOWNLOADER short code 108545
I installed Flix Vis… on my Shield Pro and Google said do not install this App as it’s a virus designed to steal all your information. Nevertheless, I installed it as Troypoint said it was good to go. I just noticed that Shield Pro stripped it off my device. Personally, I think it’s funked up that they can do this. I’m sure they also know everything I’m streaming on this device. Any comments from the sage streaming members are greatly appreciated. Thank You all inadvance.
I have it installed on my shield pro without any issues. After install I ran Malwarebytes and it was clean.
How the hell do they strip it off my device? Should I try to follow TP direction on installing it again? Thanks for your help, you’re my guardian angle ![]()
I have no idea, although I have play protect disabled on my Shield Pro.
