How to Install FlixVision on Firestick & Android TV
i doubt i will ever use it again but it was new and wanted to try it but wth ads forget it
You didn’t scan it on virustotal.com then. I posted screenshots of my results. I’m guessing you probably scanned it on your mobile 2.5 app version of virustotal which is not as up to date as the online scanner. If you’re going by the Troypoint scan shown on the main site, look very closely at the version he scanned. It says version 1.0.1, a very old version. Look closely at the date of the scan. It says February 14, 2023. Almost a year ago. Screenshot below is from troypoint.com
Be careful.
Always use the VirusTotal app or website. This new app has 2 virus finds listed.
Go to virustotal.com or Troypoint’s toolbox.
That’s interesting - never seen any ads on v1.1 or v2.3 but I can’t get the menu options to respond on v2.3.
Silly me - I had SurfShark running in the background. Without SS/CW you’re right, riddled with the worst ads!!! And I still haven’t been able to get the menu buttons to respond on my 2nd gen 4kMax (they works on older sticks).
It’s outstanding !!! Simple to install there’s several ways too! It’s fast .***Haven’t had any issues no buffering !!
Another great option of you don’t mind installing a simple build or using 1;with Kodi… Highly recommend the non debrid build Onyx… It won’t disappoint U
I’ve been trying to use FlixVision now that v2.4 has fixed the menu issue but after you’ve found a program you want to watch, it falls apart. First of all, most of the listed streams don’t work; second, once you’ve found one, you have to diddle around with a mouse pointer to get it to play; third, once you’ve found and clicked on “Play” with your “mouse”, you have to diddle around with the mouse again to get it to play. Too many unnecessary steps - pity as it looked good at first. Uninstall and use Onstream!
Interestingly, the Troypoint review mentions none of these issues - it stops after installation and mentions nothing of using it (?)
When I try and download the flixvision app, I gets warning saying this app is fake?
It does say I can download it anyway but I’m not sure if it’s safe or not? Anyone else getting this message?
I’m downloading it on a Nvidia shield with downloader.
Thanks
When trying to download flixvision app, it says this app is fake? Has anyone else got this message?
I have downloaded it on my Shield pro and done a full configuration without problems. Even scanned with Malwarebytes to be safe after Troy had 3 warnings, all good here. Integrated with RD perfectly. Using MX Player from Troy’s :toolbox:. but the 4k do not play well at all. Lots of stuttering. I dropped down to 1080 and they played well. This app does not seem to trigger the AI upscaling like Stremio does. Odd way to find all episodes in series, you have to click play on an episode and then the window pops up to choose season and episode. Live TV works but no EPG so you have to have a TV guide app and know what country and what channel you want, and easily geo blocked content. Live TV did play smoothly for me. Lots of different Countries and channels in those countries.Cannot add either m3u or m3u8. Says it’s unable to find the file. I will spend more time to check where I can get the playlist file and download it to then try it. I do like that you can click on an actor to find all the movies and series they acted in, like Stremio use to. The landing page for movies or series can be a tad awkward as it changes from one time to the next and actually removes shows you click on, but I got around that by going to Home in Flixi on the left panel and then opening the side panel a second time and scrolling down to Movies or Series. I have not tried the Adult section, but do like that you can set a parental pin for it. All told an ok backup. It won’t replace Stremio or TiViMate for me, but will replace OnStream for movies and series, especially with the easy RD integration. I also chose RD sources only. MX Player did ff,rw, pause and play in a movie or series. No ads anywhere, well except in live TV of course.
Please don’t make multiple posts for the same question. Thank you for your co-operation.
Yes. Tried it with Surfshark off as well. No difference.
Where are you downloading the apk from?
they have there own website with downloader code or apk listed
There’s where I got it from. The link Troy posted.
I got the same message from my Shield, but had no problem on my 4K Max stick.
What’s the worst that can happen if I continue on the Shield?
As mentioned I installed it on my Shield Pro without any problems. Works very well.
From Troy’s posting on Troypoint.com:
“In the guide below, we provide installation instructions using a [Fire TV Stick 4K Max](https://amzn.to/4035RIr). These steps will also work for all variations of Firestick & Fire TV”
There are so many errors and out of date postings on Troypoint.com that it would be nice if someone can confirm the following:
FlixVision (2.3, 2.4 and 2.6) works fine on my old Firestick 4k (OS6) and old 4kMax (OS7) but NOT on my new 4k Max (OS8). When navigating over to the menu bar on the left, clicking on anything results in no response.
Can someone confirm this on their new firestick 4kmax (the 16gb version) or confirm that it does, indeed work on this device?
Uninstall/reinstall. I just tested again on my new Fire TV Stick 4K Max and left menu and everything else working as it should. We sent this tutorial out to about 1 million with no other complaints about this menu problem. Would have definitely heard it here if there was a problem.
Please provide more details about “There are so many errors on TROYPOINT site.”
Of course we aren’t going to be updating articles that aren’t relevant anymore as we have over 2,000 of them. We do the best we can with keeping up with the most popular apps and addons.
“The other guy” has done this several times (and I’ve been doing this for 10 years - so I don’t think its user error). Still no go on this 4kMax.
Troy: Did you test it on the old 8GB 4k Max or the New 16Gb 4k Max?
I posted this so that folks can respond in the affirmative or the contrary. If no-one else is having this issue then it points to a defect in my 'stick.
I posted an issue with Kodi and the OS7/OS8 devices and certain MP4 files a couple of weeks ago that “no-one was seeing” here. Interesting there were numerous posts on Reddit and a solution (turn off hardware acceleration). So not every issue posted here is “user error”.
