How to Install Diggz Xenon Kodi Build
21.2..its weird
If you are using a vpn, try it with it off.
If nothing seems to work maybe try to delete kodi and reinstall the wizard.
Is Diggz Xenon different from Enigma?
I am not familiar with Enigma. Its not part of the Diggz builds that i am aware.
Xenon is one if the multiple builds/skins offered by Diggz.
STEP 5: Speed Boost Tweaks (Optional)
  • In Skin Settings > General, disable:
    • ā€œEnable animationsā€
    • ā€œEnable blur effectsā€
    • ā€œEnable widget auto-scrollā€
These save GPU/RAM — helpful on Shield TV if you want max speed.
have anyone ever try to play around with diggz build so much to learn it so perfect I never touch anything.
I have just downloaded the Diggz build to try out and am having problems finding out how to close it down
I’m hoping by now you found out. But just in case…
I realise that is the normal shutdown button, but it doesn’t do that on my set-up. Depending on the section I am in, it just takes me to an item in it and the only way to close Kodi is to force shut it. I have been through all the menus and can find nothing to do with closing the program and now I don’t even have the 3 buttons on the bottom left.
Without any visual of what you mean i am not really sure how to answer.
Did you go through the whole set up process in the setup wizard? Meaning setting up the Logins (addons, debrid and trakt) and selecting a build/skin (xenon, xenon2, fenflix etc).
If so, where in the build (which one) can you not navigate to shut down?
Is the Home button an option?
o
Yes, I followed all the steps for setting it up and although the Home button does show up under some menu options, it wouldn’t let me click on it. I have now found a skin with a menu option to Exit and is now working OK. Thanks for your help.
I have just installed this build for the first time and find it simple fast and effective, the only thing I did not like was the weather app. It seems ugly and out of place it spoils the look of the build. But after a little look around I discovered how easy it is to uninstall. I watched several movies yesterday and they played flawlessly without buffering or any stoppages. I have also recently used the Freedom 21 build and although it also works brilliantly the graphics are a little on the grainy side but given the current builds it would be my next choice. And just in case anyone is thinking about the No limits Magic build it installs but no longer works for me, if it did, I would still be using it. Thanks to Troypoint this is an excellent site.
welcome
I got a message stating Diggz Xenon developer retired. In the past I heard this before. Looking for the next best Build for Kodi
Not sure where you heard this but the Diggz Forum is still up and running just like his builds. He even replied to posts today.
The only person that i heard ā€œretiredā€ was the developer of Account Manager which is used by the Diggz builds. Maybe thats where the confusion is.
The 709 builds has retired. If ya wanting to try a new build i recommend the red wizard builds. Ya can download a kodi fork on downloader the code is 2448595
Redflix build is good.
Yeah thats where the Account Manager addon came from.
Zaxxon was the developer of 709 repo and Account Manager. Xenon is a Diggz build.
Yeh gutted as i always use his builds.
I’m late to the party :tada: for some reason I’m unable to download diggz. I get an error saying link cannot be found.
Send help
What url are you using? Also make sure its at least kodi 21. Kodi 21.2 is the latest and recommended.
The current one is https://tinyurl.com/diggz123
Make sure its typed exactly as posted.
If still having an issue try turning off your vpn until it loads.
And Welcome to TroyPoint SB_3!!
Thank you for the response and welcome. I’m up and running!!
Thank you,
SB
