How to Install Diggz Xenon Kodi Build
Originally published at: How to Install Diggz Xenon V3 on Kodi (Updated)
This in-depth report of Diggz Xenon Kodi Build will provide you with everything you need to know about this build on Firestick, Fire TV, Android TV Box, or any other device. Diggz Xenon is one of the most popular Kodi Builds available today with tons of streaming content in one location. Is the Diggz Xenon…
Is this currently down? I’m following install instructions but no joy. Thanks
Just tested in Kodi Fork and all is good. Downloaded the Nexus Wizard and then the Xenon Plus build.
Where are you having the problem?
Same, I don’t know what’s going on but I try to download the build on my fs and it’s not working… just keeps on coming up with an error after it downloads to like 3MBs🥲
Whats the error message? I just tested again and it downloaded fine.
Do you have enough storage space on your fs?
hi,
I am trying to install Xenon following your guidance but it tells me it cannot connect to server. My set up is a raspberry pi 3 with Kodi Leia 18.7.
some help please.
Just tested and its working.
Make sure you “allowed sources from unknown device” on your device as well as in kodi.
Also check for typos in the URL.
Your kodi is pretty outdated. May not run a lot of addons properly. You may want to consider updating or trying a newer version on Troys Fork options.
I tried to install on TP Fork 18.9. The download works but the repository isnt accessible. Or at least i can’t find it because its not there after i instal from Zip.
My guess is the repository isnt compatible with Kodi 18.
Thanks for your reply, I have done the obvious as in unknown sources but am somewhat confused by your advice of unknown sources on both my device PI 3 and Kodi.
I have spent a good few hours with a new OSMC installation trying to get Xenon installed, I get as far as install from zip but that just shows an empty list so I can go no further
regardsl
Yes. After i tried it on 18.9 i ran into the same problem. It says Diggz Repo updated but you cant install the Chef Wizard.
My guess is the repository/Chef Wizard isnt compatible with kodi 18. Looks like you need to update kodi version to get it to work.
Edit: i also tried on Fork 19.5 and had the same issue.
Works with Kodi 20.3
Dont worry about “Allow from unknown sources”. You had the settings correct if you were able to get that far.
Confirmed from The Chef on their website.
The Chef Wizard is only compatible with Kodi version 20 only and soon to be 21 only.
Again many thanks.
I am having the same problem. I have tried installing the build on a 4K stick and a Nvidia Shield. I get an error that it cannot connect to the server. I have tried it with using both http and https since depending on which instructions you follow both are used. I have the same problem with the addon as well. I get the exact same error. This is a clean install on Kodi. No other builds or addons are installed on it. I am using the latest version of Kodi, 21.0
We just discussed this the other day.
Turn off your vpn until tou have the repository. That should allow for the download.
The post headline below says Diggz Burst but it is really for the Chef Wizard which you need to dl the builds.
I have the latest version of Kodi and with through the Diggz install guide.
I connected real debrid but it keeps telling me that I need to connect Trakt - do I really need both real debrid and Trakt?
If you dont want trakt you dont have to use it.
Two options if you dont want to use Trakt:
  1. Depending on the version of Diggz you are using, there is an option to hide the menus you dont want to see/use. Such as, arcade, YouTube, Trakt Movie and Trakt TV. Hide them and you wont get that message. Or…
  2. Click “Never” when it asks you about Trakt and it wont bother you again.
Trakt is free and useful if you watch a lot of tv shows. For Movies it is good too but not as needed.
Have Xenon burst v2 …when clicking on on xenon burst v2 while having Xenon burst highlighted it displays a update build called Diggz AIO Version 1.2…did some build searching on troypoint and KODI no info on what type of update if any this is .does anyone know ?
Diggz has combined all of his builds into a All In One (AIO) build. This means you will have available all the Free and Debrid versions.
The latest version is 1.2.
There is a thread on this somewhere. I’ll look for it. Someone was having issues but never replied if the issue was corrected.
You dont have to update but the regular Burst build will no longer be updated/maintained. The addons should still receive them.
Here it is.
Where are the custom add-on sets located that show up on the bottom of each home screen category on the skin. I would like to rearrange the add-on sets in the default skin settings, but cannot figure out the paths to them. Using Xenon Plus skin and really like it but can’t figure out how to customize to my liking.
