I am having a lot of trouble navigating the build. Getting to the place to authorize real-debrid oe premium I’ve for all the add-ons is so frustrating. And even after I’ve authorized real debrid it comes back real-debrid not authorized. Isn’t there a build that will just require one aurhorisation? And the speed and quality is terrible. I have fiber optics and was expecting better quality, but no joy here.
What device are you using? Older/slower devices may cause slow loading.
Did you load a skin and apply? If so, you can bypass the initial debrid and addon process and do that after you load up the skin. Some people have an easier time setting up that way.
I’ve just upgrade to Diggz AIO Debrid Version 3.0 on my Fire TV and cannot install the Xenon 2 skin. I was able to get Xenon Plus to install, but whenever I try to load the installation (dependency) files for Xenon 2 I get an error message saying “The dependency on resource.images.recordlables.white version 0.0.1 could not be satisfied”. Any tips on how to get the skin to install? Thank you.
Not sure. I upgraded to 3.0 earlier today and loaded Xenon plus. I just tried to load Xenon2 from the Setup Wizard and everything went smooth. Although i didnt actually switch skins but the skin downloaded.
Try a fresh install to see if that helps.
Or ask on the diggz forum. They should be getting questions about loading errors.
I have Kodi 21 and i just looked on diggz website and some was saying their vpn was causing so i turned mine off and it installed then turned it back on after it force shut down on kodi…but thank you for replying
Hi, I have been using the all in one build with RD and it was working great until the latest update to latest version. When I look for anything I can see links in RD and free but when I click into them it says there are no streams available. I reinstalled the build reactivated the RD all is authorized but nothing is working. Not sure if there’s a glitch in the latest versions… is there a way of reverting back to previous version of the build? Just for reference I have omega 21 installed diggz with xenon 2
Hi im having a problem with downloading the latest update to xenon with chef wizard..i get the wizard downloaded and whe i try to download build it gives me an error check log message..ive tried everything..grr..the real crazy thing is i have a couple of amazon cubes and it downloads fine on them ..any suggestions??..im at whits end..thx
