How to Install Diggz Xenon Kodi Build
No problem. Do you know what fixed the issue? Just in case someone else has the same issue.
Hi All! This is my first time posting in Insider, but I’m a long time subscriber to Troypoint! I just updated my Kodi to this Diggz Xenon 21.2 Omega (AIO Debrid/I have real debrid), and having issues! I Uninstalled Kodi twice, installed Kodi and the Xenon build according to the latest articles (once with my Surfshark VPN on, and once with it off). I used the suggested https://tinyurl.com/diggz123 link both times. Even with installing every add-on that would install (6-7 worked) within Diggz Xenon (FEN light, Seren, Umbrella and etc), I can’t get a single movie to play! I’ve tried several movies and links throughout all of the add-ons.they all try to load and show available streams, but they all end up saying No streams available, or just don’t play. Is anyone else having issues watching movies with this build? What should I do? I’m using a Fire TV Cube and Thanks for any assistance!
Did you authorize your Real-debrid account? Is it active (not expired)?
You can do it when you first set up Diggz or after you install the build you want. If you arent sure, go to Xenon Plus menu and click down to Debrid/Trakt login.
Its a little different than how it used to be since Account Manager is no longer available.
Take a look and see if that helps.
Yes, it is set up / authorized, and real debrid is active (not expired) for a few more months
Then I am not sure why you are having an issue if Authorized and account is active.
I would suggest verifying you are authorized for the addons.
To double check go to Debrid/Trakt icon in the Xenon Plus menu. Select ā€œAuthenticate Debrid with Debrid Managerā€. Select ā€œManage Accounts" (second tab). Scroll down to ā€œView Authorizations".
It should show all your addons and whether they are authorized for Real Debrid.
Other than that I am not sure why you are having issues. If I think of something else I’ll let you know.
Firstly, let me point out I am almost 80 years old. I recently installed this build on my Android TV box. At first, I wondered why all the hype, I was disappointed with the wallpaper the creators had put with the build, they are so uninspired. I discovered yesterday that you can actually access a large number of wallpapers and install them so very easily. And if you want to change any, they are simple to delete and exchange. Instead of just liking the build I now love it as I have it looking like old favourites such as Xanax, and No-Limits Magic build. I was looking for a more visually appealing build but discovered that altering this one is a breeze. I am so impressed with the way we can actually alter so much of this build to improve the way it looks and how we use it. Why is my age relevant? Because if an old guy like me can get into figuring out how to solve build issues, then it must be a breeze for youngsters. Hats off to the people who created this build.
installed xeon build yesterday in the usual way. diggz1.me/diggzrepo
today there is no xeon build? anybody else experiencing this, or am have i drank too much and missing something simple?
The developer was updating his build. There is now the ā€œXenon 4kā€ build (debrid only). As of now there are no other Diggz builds to DL until/unless he brings them back. The other developers builds are still available.
If you have an older one installed already i recommend backing it up in the wizard in case there are issues or you dont like the changes.
At first look, it seems like some cosmetic and navigation changes. You can choose what appears above by clicking up in the category and selecting an option.
Running smooth for me but it really hasn’t been available to test out for too long.
Maybe @TROYPOINT will do a review/setup post.
Haven’t had a chance to install it yet.. Does it require real debrid or some other type service? I am currently using the free version and i Dont want to uninstall it if the new version doesnt do the free version
This is a Debrid Only version. Keep your current build for now. He may update the free version at a later date but I have no idea.
anyone recommend a good build like the xeon free version?
Hi, sorry for the trouble, after following and installing the newest Diggz, the only Xenon I’m able to get is the Debrid version, not the free version.
Yes. Right now the Xenon 4k is debrid only. Hopefully you backed up your older build so you can reload it.
Keep an eye out in the wizard to see if/when the other builds are available.
Hi thank you, but in the tutorial, it shows Diggz Xenon free V1.0—- I don’t get that option.
The @TROYPOINT tutorial is somewhat out dated. Right now as of my reply, (9/26/25) the only Diggz option is Xenon 4k. Unless you had one downloaded already.
Build developers make changes all the time and it’s not easy to stay on top of them all.
That’s why TP is a good way to get up to date info from every day users.
Also this is an old tutorial thread. Troy did justsend out an updated email today on how to download Diggz 4k.
Some of the pictures are from previous versions of Diggz builds but the main instructions are up to date.
The Xenon Free (version 3.1) is now available in the Chef Wizard.
Make sure you add the source
I just added the diggz xenon build to my ONN box and the first daybit was glorious. But I’ve noticed all morning long when I try to watch something on it I get nothing connection. I tap the kodi symbol and it just goes black screen. Anyone have any ideas what it could be?
I just installed the new digging xenon build on my ONN box and the first day it worked beautifully but now when I got to get on kodi the screen stays black. I’m getting nothing. Anyone have any ideas.
Open your device settings, click on apps, then on Kodi. Force stop Kodi, then clear cache. Back out and restart Kodi. Hopefully that will work for you.
