How to Install Diggz Xenon Kodi Build
This will probably get moved to a Diggz thread. Try to search before you post.
If you click “Xenon Plus” on the main screen you will get many setting options.
Under Xenon Plus go to skin settings then to add-on shortcuts. You can delete or add the icons you want.
I am attempting to update Diggz Xenon to the newest version but when I get to install from zip file and click on the diggz file Kodi crashes. I have tried it with my VPN connected and disconnected with the same results. Any help would be appreciated.
Welcome back!
Use https://tinyurl.com/diggz123
This the working url. Search next time. It been discussed for weeks now.
Any questions after the install there are threads for that as well
I did search and did not find it. I think this may be only my second post on here ever and I am not familiar with how to maneuver the site, but I thank you for your reply.
No problem. It said you havent been active in 2 years so thats why I welcomed you back.
Not sure the last time you updated Diggz but it has changed over the last few months.
There are diggz threads here if you need help.
Thank you.
I use diggs all the time and have updated it before and never had a problem. This is the first time I have experienced a problem updating the build.
I am not the sharpest tack in the box when it comes to computers. Usually get myself in trouble. :grinning:
I went on YT … searched for new diggz url and a video with instructions was one of the choices.
Wow i have shield and my neighbor wanted to put kodi with Diggz build and a sport app that shows NFL but i so forgot how to mess with the fire stick how and where do i start to get go tv, movies ,and sport
If you use the search button all the info you need is on here
Here you go:
It there a way to update the addons on this xenon plus build. Thanks
I explained this to you in the other thread.
I had the same problem
I disconnected my SS. And it worked and installed ok
Don’t forget to connect VPN after installation.
Needing some help. Nothing is happening when I choose the Authenticate RealDebrid. Nothing happens. Installed everything brand new, even Kodi. Gets all installed but then selecting RealDebrid nothing happens. I was assuming it would pop up with a code. No such luck. Any ideas?
I also have the latest version of Kodi and went through all steps of the Diggz install guide.
I also tried using VPN and without. I thought when you set up you don’t have VPN on, until you’re ready to start watching and using the service.
I am guessing you are installing the new 1.9 AIO build.
I noticed on my Onn Pro i needed to wait a little for things to load in the background. Eventually the code popped up.
When i installed on the Nvidia it loaded much faster.
I would suggest to close kodi and reopen and wait a few minutes. That should clear up any possible back log.
Edit: i just tested on my onn 4k (non pro) and it takes time but it will work. Its a slower device than the other two.
Another option is to load the skin and authorize Debrid and trakt once you loaded it up.
It won’t let me continue to just add skin. Not sure why. This was working befor Xmas for me. When I got home from holiday it didn’t work anymore. Idk. It’s just stuck at the two options. Step1: debrid and trakt logins and Step2: install skins.
Hey thank you for your response. I’ve waited for like an hour. It doesn’t do anything once it gets to the two steps. Not sure. I’ve wiped it twice and started from scratch.
Edit: Well, it finally worked. I didn’t do anything honestly. It just popped up with code. Wow.
How do I uninstall this colossal piece of crap? It doesn’t work.
