Good to know. Thank you @Miki !
Thanks for this recommendation. Iāve closed a few of the Stremio posts and moving forward troubleshooting and Stremio fixes will all be directed to the following.
Hoping people watch the video in that post as it fixes most problems.
It was easy for me to just pay with cash app
This should be a headline:
On April 11 it was announced on the Torbox Discord that Torbox was going to discontinue their Stremio add-on.
No timeline was given for the action, however.
Oh well. You can still use your API key in any addons that allow configuring debrid accounts.
Tx for the update @elginherd
Thanks for this info!
Their post indicated that Torbox wants to stick with their knitting, so to speak, and that there are more than a few add-ons that do the job as well or better.
But thatās just their addon, the API is still active to add to other addons.
Please, NO! Itās getting impossible to find any specific issue now when itās buried in a stream of 5,000 other posts that have 1 word in commonā¦ā¦ā¦ā¦ā¦..
@sktn77a I agree. Plus important news or a new problem gets buried in more general topic.
@Miki Yep. Torbox is a great debrid service, for streaming on Kodi, Stremio, etc, but itās not the only utilization.
Oh I know. I have a pro sub. But I donāt think thereās anything I can do to change their minds. Just have to accept it and do this best we can with their decision.
So for us that are more than a little slow does that mean that if we just bought a torbox service for our Stremio account itāll no longer work?
@Kayak No. It does not mean that. If you authorize Torbox in a Kodi add-on or into a Stremio add-on like torrentio or comet or elf hosted, etc, etc itāll still work.
It just means you can no longer use the TorBox addon by itself, but you will still be able to add the TorBox Debrid API key into other addons that accept the integration of Debrid API keys into their setup as @elginherd has pointed out, which is the way most ppl use it.
Says the one that doesnāt have to manage the site. If they didnāt merge threads you would have dozens of threads basically about the same thing
So I watched the video, made an account with Torbox, and it shows up in my addons. But it doesnt show up as a separate debrid service when selecting a movie. it shows combinations like ācomet/TBā or mediafusion/TBā but not Torbox on its own. Also its not showing the Utorrent addon option to select from either, and its in my addons.
It looks like you have used the Debrid API key in the addons. With the possibility that TorBox will remove their Stremio addon I would just use the key as you seem to have done as that will be the only way going forward it seems.
This isnāt about installing as much it is about fixing a problem with Torbox. I have had it for awhile and at first it worked pretty good but over the past number of weeks it fails to produce anythink. It probably is all about me but I have gone back and tried many different approaches. I have it on Stremio, doesnāt work, Nuvio, doesnāt work and Strmr, doesnāt work. It always shows that the API is either incorrect or invalid. I have gone into Torbox and regenerated a different API number and put it where itās supposed to go. I guess starting from the beginning would help. People have talked about using the manifest url in Stremio but not sure where that would be. Just point me in the right direction and Iāll deal with it. Thanks
Remy, what add on are you using with your Torbox API? And this is a dumb question, but I have seen it happen before. Is your sub still active and not expired?
