Fixing Buffering!
Hi! Not sure if this is the correct place to ask about buffering so forgive me if it’s not. I’m at the end of my tether trying to stop buffering on iptv. I have Firestick and Mecool k2 box. My WiFi download speed is over 100mbs. Use Smarters and TiviMate premium. Tried lots of info on YouTube but nothing seems to help!
Any help/advice would be greatly appreciated.
Many thanks :blush:
Hey @kapete Have you watched the Troypoint buffering vids…force closed apps & cleared all caches, cleared storage cache on your K2…rebooted it & your router? Your speeds look very good, so…if you’ve done all that & still keep getting lots of buffering…I’m gonna say it’s probably your iptv service. If you would, private message me who they are as I’ve tried lots of them & have a decent idea (at least in my humble opinion) which are most stable.
get a VPN
this will help
Buffering usually comes from inadequate download and upload speeds or signal strength from your Wi-Fi. Case in point: I consistently have very good wi-fi download and upload speeds in excess of 15 mbs upload and 50 mbs download using my vpn service. I clear my caches and clean my device memory every 2 days. I have no buffering whatsoever with these consistent download/upload speeds. I use Analiti and AIDA 64 apps to keep track of my wi-fi and device performance. 2 days ago, my internet provider had some temporary transmission problems and my speeds dropped to 25 mbs download and less than 5 mbs on the upload speeds regardless if I used the vpn or not. No one talks much about upload speeds but you can’t stream very well if it is under 10 mbs. Your speeds for streaming will never be better than your weakest link between your wi-fi, device, vpn and internet service. At a minimum, you should try to 1) get internet service with 200 mbs/25 mbs download/upload speeds, 2) a good wi-fi location for your device that gets a good or better signal strength from your wireless router, 3) a good wireless router with 3 bands and sufficient area coverage and signal strength for the size of your home, 4) android quality streaming device with at least 3 gb of RAM and 32 gbs of internal memory.
Hi thanks for you reply.
Not sure how to private message you! Can you tell me?
Kapete
Thank you, I will check out your suggestions. :blush:
Thank you. Have a vpn…iPvanish!
Adjust your buffering settings in Tivimate to a larger size.
Increasing your buffer size is a big help.
Thank you! Will try that :blush:
Hi. Can you private message me which iptv service you think is the most stable? Thanks in advance.
…not sure if you are using a router but sometimes changing the DNS servers can speed up the internet a bit and help with buffering. Its not just specific to routers I just find that an easy change to make to see if it helps. :+1:
I found when I went to ethernet and not wifi, it fixed my buffering problem.
buying a 5G router solved my buffering issues,l had annoying buffering on 2.4G router,changed to 5G and and had all my devices switch to that band and no more buffering…ever…i’m so happy…even 4K works great w a great pix,this worked for me
watching 4K content now is awesome!!! 5G for me
Ok you guys; now you got me wondering. I have been using my streamlocator on my Nshield for quite awhile using wi-fi. I don’t get a lot of buffering, but I do get some. Either way, would you suggest using ethernet or sticking with wi-fi. While I am at it. Between wi-fi and ethernet, does one use more data than the other.
Ethernet always preferred…no more data.
Thanks, I will plug it in now. !
Ethernet cable is a direct connection and there is no signal loss, unlike wi-fi, so it will always provide the strongest connection and speed. That said, as long as you can get a strong signal while using 5G Wi-Fi on your device, there won’t too big a drop off in internet speed. As long as you can get 50 plus mbs download and 15 plus mbs upload speeds while using your vpn, you shouldn’t have any buffering problems while streaming in high definition.
I also plugged the ethernet to my computer back in, and the ethernet line I have running to my Km2. Hopefully I will get better data reports. I used the wi-fi before because I was told that it is much faster than ethernet.
