i get access denied permission code13
I used the 444801 code in the installing elementum vid; but it just stays on redirecting. I also tried https://troypoint.com/elstable. Same result. I saw other people having different problems after downloading; but I can’t even get it to download. Any ideas?
Thanks, I’ll give that a shot. The other is still redirecting, hours later ![]()
Which file do I want? There are a bunch.
Did you read what it says?
It is always better to use “All-on-one” zip file to install, it includes all the platforms!
If using a VPN, disconnect temporarily and try again. I just tried 444801 and it is working fine on my end.
When I install elementum using this method I get “permissions denied”. Why?
Just tried using code 444801 and I’m getting a status message saying
“ an unknown error has occurred. Check your url and connection any ideas on how to trouble shoot?
Trying to download Elementum
Maybe a silly question but did you turn off your VPN before downloading?
Thank you, this worked on my fire stick. I just didn’t delete the file when I used downloader and went to install zip file in Kodi and it was there. The Gaia url doesn’t work, but this works. Appreciate it
want to install elementum on my firestick but downloader code 444801 says refused. how can i fix?
go to system then file manager then add source https://repo.gaiakodi.com
Elementum does a great job with finding video. Much better than many of the other plugins. – but are there other plugins that are comparable ?
Hi, newbie here. I can’t install Elementum. I keep getting that it is “not compatible with this version of Kodi”. I have upgraded to the latest version of Kodi. I disabled Surfshark and tried everything again but no luck. Where did I go wrong and what can I do to fix it?
I dont use it, but Diggz has a free addon (Free99). Not sure how it compares to Elementum as i use neither.
Diggz also has 2 builds (skins) that dont require a Debrid account.
So probably a silly question, but when using Downloader to add zip files and repos within Kodi, is there any point in keeping that downloaded file within the downloader app after everything is installed?
Will the repository for say, elementum, stay updated without the downloaded zip file in the downloader app?
Deleting from downloader is mainly for storage space.
You can keep it there and use it again if you have the storage space. Ive kept things in downloader and and reused them in the past. However you won’t get any updates to the downloaded file.
It won’t interfere with how it works when installed and used from Downloader. The executed zip file should update just like any other addon in kodi.
Hope i made sense.
Hi 4kperson! Welcome to the Insider.
Just a suggestion…I assume that you followed Troy’s tutorial on installing Elementum. It is considerably different than the usual addons for Kodi I recall several sequences that have to be followed to make it work. If you haven’t yet, you might want to watch Troy’s video.
Hi Matteos, I’ve always religiously followed Troy’s suggestion on deleting the installation files. I’m certain, like JPM60 says, that this came from the Firestick days where memory space was a precious commodity.
