Downloader Browser Not Working
This may have been raised before, but i have searched.
I have downloader installed on my backup sd card. Today i installed it onto my Ugoos AM 8 device.
But when i typed in a code, i was greeted with " The web browser is disabled in this version of the app".
Any advice appreciated. Thank you
Make sure you’re using the latest version. That sounds like the older one that had that issue and a subsequent release fixed it or readded the browser function.
Thanks miki. Will look for the latest version.
This is one of my favourite apk sources.
Thanks miki. Excellent link and worked a treat​:grinning::pray:t2:
Latest version of Downloader is also in our Toolbox. You can open toolbox in browser of Android TV Box and go to TROYPOINT Toolbox and install it from browser.
Mamy thanks. I have managed to do that.
Latest version of downloader i was unable to scroll down to download like kodi, virus tool, aptoide app etc.
I just serup my Formuler z11 pro max and when I put in the code .the page came up but i couldn’t scrow down on the downloader page. I can scroll down on troy website and toolbox. I haven’t tried a different code to see if happens.
It was in mouse mode and i tried without mouse .still happens
Advice Please or image of what to do? I would appreciate it.
Thank you
Any chance you enabled the developer options? One setting in the page transition settings messes up the mouse mode if you set it to .0
Hi miki , i did enable developer options. I will look at the transition setting. If its at 0. Then whst setting to i set to?
What i dont get is i scroll down on other websites, but donwnloader will not let me scroll down with mouse or the up and down arrows.
Thank you for help so so appreciate it
I will get the exact setting for you as soon as I fire the old Shield up. There are 3 and I think it was the last, but I’ll check to be sure.
Ok I have it. There are 2 options you can set to off and one to .5x they are under the “Drawing” section.
Window animation scale
Animation off
Transition animation scale
Animation off
Animator duration scale
Animation scale .5x
Now if that doesn’t seem to work, then start with .5x for all three. Fingers crossed.
Thank you thank you
I will let you know how it works out. I get back to sometime sat or Sunday.
Hi thank you for all your help. I did all the changes and the downloader works correctly… there is a box that comes up after I turn the box back off after turning it off from the previous night. I will take a picture of it. I don’t know what it means. If you can tell what it means that would be great.
for me to use the mytvonline 3 I need a portal or mac address correct? My iptv service I’m using there epg guide. I don’t have the portal or mac address info from them yet. I haven’t received from them.
thank you.
Mytvonline 3 is only for the Formuler boxs. If you’re referring to using a paid IPTV service then those credentials go into a player like TiViMate or Sparkles.
Hi yes I have formuler z11 pro max. Yes paid iptv service. so i can’t use my iptv paid service in mytvonline?
If you have a formuler and it has the mytvonline3 then yes you can use your subs in that app.
https://troypointinsider.com/t/formuler-z11-pro-max-first-impressions-video/80552
As you can see, using the search will yield a lot of helpful results for you to use.
