Hello, again,
Two TVs, two different devices, same wifi speed, same apps; one works fine the other not so much. And we all know has the device that doesn’t work for her. I have an ancient MXQ Pro and a newish Fire stick. We clean and reboot them daily. Update things as required. But the Fire stick just doesn’t want to play nice. I can pull up the same app, the same program and the MQX loads while the Fire stick doesn’t or buffers like crazy if it does load.
Is there a fix to the Fire stick of should I be looking for something else?
Speaking of which, in a perfect world what would be the ideal setup, device, internet speed, etc, any suggestions?
Thanks in advance.
Bob
There is tons of info here. Try this:
apples and oranges, 2 different devices. Pick your favorite and run with it, master it and you will be good to go.
Old sticks should be put to rest and get a Max or 3rd gen cube. The dif between the Max and the last 4K is huge.
@anon36991227 posted a ton of valuable links. All are good reading and helpful.
Hello,
Thank you all for your information and links. It seems no matter how hard I try to find the answers myself I seem to miss a few.
Thanks again.
Bob
