here it is animated
here it is animated
Ohh better yet. Tx bunches. You guys are the best.
How do you download real Debrid onto the streamio app
Didn’t realize I couldn’t talk about this stuff. I hear everyone else talking about what they’re doing what they’re buying what they’re hooking up what works and what don’t work, I thought Troy ran this site. I don’t know who you are and why you’re telling me all this.
If you read the rules you would have known.
I am one of many ppl that help Troy to run this site and in particular the Insider. You seem to be upset and I’m not sure why. It doesn’t really matter who I am, anyone can flag a post that violates our rules. If you look at my Avatar you would see the attached “Leader”. Our rules are very limited but the ones we do have are important. Allowing posts like yours could result in a legal notice to Troy and trigger a potential shut down. Here is the exact rule.
Do not mention copyrighted TV shows, movies, sports franchises (NFL, MLB, UFC,), etc in conjunction with unverified apps, addons, IPTV services, debrid services, etc. Do not post an image depicting the same. Examples of 3rd party apps/debrid services are Kodi, Stremio, Syncler, Cinema HD, Real-Debrid, Premiumize, TorBox
So here is where I think you didn’t understand.
No mention of IPTV services or linking to them unless you are a TROYPOINT Patron or Founding Member and in that case the topic should be placed in ‘IPTV Services’ category.
If I can do anything to help you in the future, please feel free to PM me. Have a buffer free day.
Time to check your fire sticks people buy an ONN pro and you’ll be happy trust me
You don’t actually download a debrid service. You get the service and in your panel for the service will be an API key which you add onto the appropriate configuration setting when asked during the configuration of an addon.
Onn works great. I will be setting up all devices with Onn. It’s cheaper than Amazo, has more storage and is easy to use.
Works great! I have Version 3.4.3 on a Firestick 6.7.1.0 with updates disabled if that helps.
Love my 4 Cubes. There is a Cinema version 4.0 beta that’s working. I have friends that haven’t bought into Stremio yet. Ver 4.0 is helping them.
I am using onn 4K and I am in Canada! I am still using Cinema hd and bee no problem. If I see a problem coming up I have the clone app to make necessary changes.
Not sure that is accurate as they are now removing apps and blocking unless Play Protect is turned off, and many do not know about that.
I like HD Movies. Make sure download AM player to play the movies though.
The advantage with the Plus is to use the USB port for a mouse or additional storage. The $30 Pro has 12GB of useable storage which is plenty. I still use the original Stick version on 1 TV but have it dedicated to sports apps. Have the $20 version also but it is best to never install KODI on it as the useable drive is small and like a firestick is best to have 1.4gb dedicated free space.
Download what you need from Google Play, then Disable, Force Stop, turn off notifications and clear cache from Google Play and leave it permanently disabled.
Cinema HD ? Still working for me
I am not sure what your issue is with Cinema. I still use it, but I prefer BeeTV V 4.4.4 works great.
Maybe I’m missing something.
Wish you the best!
There are many versions of Cinema HD floating around. More than likely you are using one that hasn’t been blocked…yet.
If it doesn’t ask you to update every time you start it, you’re using a modified app which might not be recognized by Amazon.
Hi All,
I have a problem with captions/subtitles on Onstream apk. Watching a video, I’m able to change the color, size of font, but the on/off toggle is not responding. It stays on “off”. I tried force stop, clear cache, as well as uninstall/install and it didn’t help. Any other suggestions would be greatly appreciated. Thanks
I am actually lucky that Cinema HD works fine with my 2nd generation firestick. Understanding that this will not last long, I am trying out Stremio. Having issues though. I created an account online, used the bootstrapper option, activated TraktvTV and added Real Debrid API to Torrentio. I have a Stremio app on my Samsung TV. All good until I try to watch something. Getting many link responses, mostly Torrentio. Once I hit play, I receive a message - “Access denied. Please check if you have a valid debrid subscription. I use both Real Debrid and TraktvTV on Cinema HD and the work fine. Sorry for the lengthy message. Any help is appreciated!
