Cinema APK replacement recommendations
Cinema APK is no longer working. I’ve used it for years & loved the ease of it. I’m looking to find whatever is closest to it that works currently. I don’t know if I’m doing something wrong or not, but I can’t get Filmplus to play anything & stremio just gives me a list of places to pay to watch. What am I missing? Any help would be greatly appreciated. Also, to Troy, after years of following you at troypoint, I finally became a patron. Thanks for all of your help - past, present, & future.
Try onstream :+1:
What version are you using? Do you use a Debrid service :thinking:
It’s blocked. I’m using Premiumize. I had real debrid, but can’t seem to renew with them.
I’ll look into it, thanks. Is it similar to Cinema?
3.4.1 is working here with Premiumize.
I went through unlink (at someone else’s suggestion), tried the new version, but it didn’t work. Went in again, tried the older version & it now works since I linked Premiumize. I’m trying to get real-debris back, that worked great.
Cinema, BeeTV, FilmPlus, and NovaTV are all currently in the process of being blocked by Amazon. Try Onstream (no debrid option) or get an Onn Device.
I’m just seeing the Onn device. I’m not familiar with it, but it sounds like something I’d like.
Yes it’s my go to app easy to use downloader code 8226594
Thanks for becoming a Patron!
We strongly suggest using Stremio. It’s free, has no ads, no malware, and simply works.
Here’s my setup video for email subscribers.
Cinema is working for me. Not sure what your problem could be.
Cinema works great (sans TorBox) on streaming devices. Roku is a far better device than Firestick. If you want to use 3rd party apps I suggest ONN Plus or Pro. There is much discussion on this site regarding streaming devices. AMAZON FIRESTICK is no longer suitable for 3rd party app usage!
Firestick??
Sadly either play the game and try the cloning and renaming, or find another app like maybe HDO Box, Ontstream, Ocean streamz, there are a ton of them out there, just make sure you have virus total to scan with so you can find the ones with the bad stuff in them and weed them out. When looking for other free apps make sure you grab the player they need in able to work.
I would be looking at other apps with a debrid service of some type, I use real debrid, also have torbox but it doesn’t work with everything. Stremio, Flixnest, I like Weyd, and if you are patient even Kodi are great and better alternatives to the dodgy apps.
Other alternatives could be a different device, depending on where you are at, or a TV service like one from Amber (see guide/write on it) most have a fair VOD set up, not as vast as what you may be used to but it may suit your needs. You would need a player like Tivimate, Sparkle, Ott Nav or Wave.
Edit to add this, in case you may be looking for a new device. It is filtered for certified netflix, but at the top under streaming devices you can change the filter.
Tried FlixNest but couldn’t get it to log in and install any addons. Looks like it needs some work?
After cinema was blocked on my fire sticks I switched over to stremio for a few days. I don’t care for the way it works compared to cinema. Some days it works great sometimes I can’t anything to play. Even with real debrid. So I made the jump to the Walmart onn 4k plus and put cinema back on it. Problems solved back to easy viewing.
Could be, I set it up but never messed with it much.
Try Bee or Movie HD. They work pretty good
Cinema still works on Onn Box.
BeeTV has also been disabled by Amazon. I suspect MovieHD will be next.
