BuzzTV X5 Review - Future-Proof Streaming Device
If I remember I plugged in a 64 GB sandisk 3.0 into the USB for unlimited storage and it has a slot for a card like you use in your camera. I really need to slow down and give the km2 another go but I’m already booked solid every day for the next two weeks. Oh well. :laughing: :rofl: :joy: :joy_cat: :confounded:
Voice command it a moot point with me. Lol. But thanks for the tip!
km2 has a voice remote.
You just have to use the back button to get it online. You can set what time you want to put it to sleep in the settings.
Hi,
Can anyone tell me if this remote BUZZTV ARQ-100 V2 will work with the Buzz 5 TV box, It’s just that I want to have an air mouse and I do not like the pointer mouse on the present remote.
I have tried to pair the remote that came with the Buzz box to the Air Mouse I was using before with the Bee Link box, but I can’t seem to be able to pair it with the new Buzz box remote.
So was thinking of buying the new BUZZTV ARQ-100 V2 AIR MOUSE KEYBOARD LEARNING REMOTE CONTROL, but before committing myself I just wondered if anyone knew if this remote will work with the X5?
Have never tried it but it should work. You can get that answer in their forum if anyone will answer :thinking:. But I can say that I use another remote with a fly mouse and it works well on the box.
Hi TX, Can I ask what fly mouse remote it is that you use, please?
I use the ugoos bluetooth remote that came with my ut8 box. Ive always considered this remote my fav and decided to try it and it works great except the voice part. No voice works on the x5 at least not yet. The ugoos pairs easy. Ive got 2 more ordered and should be here soon for other boxes.
Ah Right, Not sure if I can get that remote here in the UK?
This is the one I have always used but for some reason I cannot get it to pair with the Buzz remote.
thats a 2.4 mouse and no need to pair. You will need the usb dongle and it should work.
Ah right, Jeez, I never thought of that. I shall try that later on, I’m going out for a little while.
I can’t believe I never thought of that. Dunces hat for me I think.
Thank you, TX. I shall let you know how I get on. Thanks for all your help, much appreciated.
no problem. I have that same remote and will hook it up to test…if I can find that little usb :rofl:
Found It :sunglasses:… you will be happy to know that mouse and the fly function works well on the x5. :+1:
Yay, well done TX… :clap: :ok_hand: Just tried mine with the dongle,lol and it’s working fine. You’ve saved me some money,woohoo. :+1: :smile:
Thanks again. I shall still have a good look at that other remote as well though because as I mentioned before and also as Troy mentioned, I wish they had raised the directional buttons a little bit as I sometimes find myself pressing the wrong button. But that might just be me in my old age,lol.
Once again TX, thanks for your help.
I decided to just keep it and play with it for something to do when I’m bored, which isn’t often.
Hello @Streaming429 No, the Ugoos boxes are not Netflix certified.
I takes a little time to adapt to this box. I guess its just cause we are so used to something different. I actually factory reset mine and went back to the buzz modern setup and im getting better with it. The iptv settings are very different than tivimates and caused me a few issues but after lots of button pushing im getting there :joy:… and the remote is helpful for iptv setup I prefer another remote to navigate in a normal way…
Any idea about making categories like on TiviMate? And which remote do you use with the X5? I’ve thought long and hard and definitely going to give it a chance. If nothing else, I’ll put it on our sun porch for fall football
not going to say you cant make groups but I havent found it and also looking for the default download location for recordings or how to change it…not found that either :face_with_monocle:… Thats why I do have tivimate installed on the x5. I record from tivimate to my server via smb and notta on the buzz…at least not yet :skull:
AliExpress running a sale on the x4 currently.
