POV is lightning quick indeed.
Does POV use the CocoScrapers like Ummbrella and FenLite AM?
Genocide, FenlightAM, Umbrella, Dradis and The Gears, work with Torbox
No, I think it uses Magneto scrapers.
Iām having problems getting it working with Umbrella and I have the latest version.
Is it showing
double check the long api youāre entering, it has to be exact.
Did you install Cocoscrapers?
yes it is.
It keeps asking me for API keys for TB?
Did you enter the api key?
Sorry,Papa but i canāt seem to find it in TB??
Hello, I think I show all of that in the video above. Go to 15:26 of the videoā¦
Go to your Torbox Dashboard and scroll down.
Lol. All of us chipping in. Itās under the account section of your TB dashboard.
Just to add to this, when you first go to your dashboard click the little icon on the top right that has a letter in it and then click āsettingsā then āAccountā.
Can this api key be used on all addons?
Not all addons support TorBox but the good ones do including Umbrella, POV and then the ones mentioned in the reply above that @PapaS outlines.
Thanks for the replies ![]()
As long as you have Torbox Pro, you will automatically see Usenet results in your Stremio results when using the addon. Itās not a device-thing at all. Itās not related to Stremioās search, itās related to the sources/links that the Torbox Stremio addon finds. You will see results saying āTorbox (Instant)ā if itās cached, think of that like the RD+. Usenet results will explicitly be called Usenet.
On the Torbox site, if you go to integration settings, where you can configure the addon, you can also go to āSort Stream Type Settingsā, by default it has āTorrents firstā, and change that to āUsenet firstā
Also you can use Torboxās search engine, which is not on their site for legal reasons:
Go to search and switch from torrent to Usenet. You can search by title or IMDB ID, and can instantly add anything you find to your dashboard, which means you can then also stream it on Stremio.
Yes. It can.
@PapaS = KODI Legend ![]()
Unfortunately no you wonāt. Their stremio Integration is sadly lacking as is their instructions. I have been through every setting they have, read every bit of info they have and for Android devices they are entirely wrong in how it works and how it should display. I have Troy sending his contacts screenshot showing the lack of scraping. While other Stremio addons show higher res sources and quite a few, TorBox shows nothing or only 1. While their sources they do show say (Instant) there are quite a few that arenāt. They give instructions on how to use the search in Stremio for usenet but it doesnāt work anywhere near like they claim. There are some series that you click to start the Instant and while it does they also get downloaded which is not how it should work. Right now the TorBox Pro addon for Stremio is a mess and while much more expensive than say Premiumize does not provide anywhere near the quantity or quality of scrapes that Premiumize does. It may be good for Older stuff, but anything new or just released it is not good at all.
