Best Firestick Alternatives
Walmart ONN box 4K has been the most popular and TiVo stream 4k and Google Chromecast are other options as well
Ive been using a mecool kd3 with the usb for extra storage. Ive been completely satisfied for almost a year.
Stay away from Temu, it’s owned and run by Chinese entities that get your info.
$33.95 now for 64 &128gb Temu
Does the Onn box come with different specs, and if so, which one should I purchase as a firestick replacement?
No there’s an older one and the Newer 4K one but there’s only 1
The Onn has 8GB of memory. Is that enough if I’m side loading apps?
8GB of Space you mean. And it’s not quite 8GB. You can delete some of the preloaded Apps but not all of them. That said I run a Full Kodi Build, Tivimate, Downloader and a few smaller apps and still have just under 2GB left
Thanks
I agree 100%. Purchased one 2 weeks ago love it. Tiger Florida
I have 2 of the onn boxes they work great and easy to side load
Thank you all for your feedback.
Are these knock offs?
How do I set it up? Where do I get the apps for movies
Search Is Your Friend...!
I just received my Onn TV box. When I tried to download the Downloader App I received a message stating SOMETHING WENT WRONG TRY AGAIN LATER. Anyone have a fix for this?
Check the link for setup
https://troypointinsider.com/t/new-walmart-4k-onn-android-tv-box-first-impressions-video/89389
Stremio is a great movie app
How do you set up ONN
Thanks
