My question would be, with it set to internal storage, yes it could be used for apps but they had to be moved over or could be set for new ones to install there. When it’s internal memory, is it acting as contiguous memory, in other words once you fill up the Pro memory is it automatically going to the usb drive. My experience was it didn’t and was still seen as a drive. Please let us know.
Yea , ya see that’s what i assumed would happen. Onn 4k storage would fill and auto go to thre other shared internal. But @chillenandy321 says if i add ar.tvplayer.tv folder in my android section of xplore app that sees the thimb drive, turn add that same folder path in tivimate it will recognize it then. Gonna try it
I don’t have an Onn, but I do have an Android 14 TV box (unrooted). With that box, I was able to add a 1/2 TB thumb drive to extend internal. Not only was it added, but it was kept as exfat formatting and I was able to record files greater than 4GB.
Within Tivimate, I was able to use the file selector (not system picker) to choose Internal(root)/Download/Tivimate/Recordings as the recordings folder. You may have to create the Tivimate and Recordings folders with Xplore. The Download folder is an open writeable folder on most systems. Also you can use Xplore to navigate to your Recordings folder to view them or open with a player.
Did this work ? Inside the ar.tvplayer.tv folder you create also make 2 folders one for backups and other for recordings. The usb drive has to be formatted for internal storage only.
thanx gonna give it ho now
Okee doke. Under Android got a folder named at.tvplayer.tv and in that folder there are 2 folders 1 titled backups the other recordings. And the 128 g thimb drive is formatted as internal storage. My only question is that under Android in my xplore app the data folder and the obb folders both say access denied. Will that have any impact on tivimate recordings going into the thumb drive ?
Media folder is not denied access. I just recorded something earlier. Works fine
What are the 2 items in tivimate backups ?
No pressure @chillenandy321 , but I’m countin on ya
I don’t see a Media folder inside the Android folder for some reason. Look at my pic above I posted earlier.
Android/media/ar.tvplayer.tv/ then make 2 folders backups and recordings. By default there should be a media folder in there.
Okay gonna go at it again in few. Forgive me, but I’m a “Messi” worshipper n watchin a slugest between miami n atlanta.
Good news Messi n Miami 2- 1 WIN!! Bad news there’s no default media folder when I expand Android. /ar.tvplayer.tv/data Acces denied/obb Access denied. As you see when ar.tvplayer.tv expanded / 2 folders under it/ backups & recordings. Confused ![]()
Try and add a media folder in android folder. Then add ar.tvplayer.tv in media. See if that works. Not sure why yours doesn’t have it by default.
Thanx I’ll give that try ![]()
Just had a thought, are you using xplore fiile mgr.? Or another file mgr ? If it’s differen , I can try using that one.
What Android version is your device?
