3 Popular Kodi Addons Appear to No Longer Be Working
Yup Just seeing this news too on The Oathe.
Well that bites. I use The Oath almost exclusively. Guess I will have to install another addon to replace it. I still have The Crew and Marauder. Guess I know what I will be doing this afternoon.
Real debrid and seren is the best bet
Still working for me! :wink:
Yes if you have it installed or in a Build it should still work just not sure for how long. But you won’t be able to do any new installs as Repo is down
I may be naive, having downloaded the Repo, could ā€˜someone’ not just upload or ā€˜host’ the Repo allowing others access? Or make TheOath available within another Repo?
It was working for me except the voices on the Movies were a strange language
@TP-Brett Hi
I stopped using Fen two years ago.
But
Venom version 6.5.6 Just tested still working and
The Oath 4.11.09 also working.
Tested both add-ons with viewing few movies and tv shows all working as they should.
This just to let you know.
@Matrix
For now, untill the host shuts down the server connections. It may still work but will not be updated or maintained.
I think kodi users at this point should look towards real debird maintained sources.
@TP-Dracoo
Yes indeed. I have many other add-ons just in case :+1::blush:
I was using Oath and Venom as well :anguished:
@chuckman
I’m still using both for now :cowboy_hat_face: but you can try other ones from TP manual if you don’t have it.
Best Kodi add-ons
I’m planning on deleting Oath and Venom.How do I go about this?Thanks.
Thanks,Martin.I will check this out.
@chuckman
If you want to uninstall them open Kodi
Add-ons> to the right top Install from Repository
The Crew Repository> Videos add-ons from there op The Crew Add-on> uninstall
The Oath host505 Repository> Video add-ons> The Crew add-on> uninstall
I just re installed the crew as per instructions so its seems to be working again
@Oz_pete
Yes as @TP-Dracoo mentioned above in this topic.
For now, untill the host shuts down the server connections. It may still work but will not be updated or maintained. :disappointed: :anger:
Can you mention a few that you have please.
I have just tried installing Seren…trakt not avaliable. Mad dragon, fusion tvadd ons, venomā€¦ā€œnot available from sourceā€.
Marauder from crew has vanished from video add ons.
Thanks
