I don’t use trukt. I using Real Debrid instead
Almost all Kodi add-ons I’m using are mentioned in TP manual. Patriot, The Crew, Asgard, No One and much more. If you select one from the manual in settings you will find Trakt authorize.
The Oath and Venom still working for now but future updates will not be available as @TP-Dracoo mentioned.
To try other ones from TP manual if you don’t have it. Best Kodi add-ons
Just tried those add ons you mentioned. They belong to the narcasist repo, which will just not install for me. Double checked for typo’s…still will not install.
No I don’t think so. There is hundreds of Kodi add-ons, scroll down and check the content table.
But I think you should try this one from TP manual dabutcher repo, when you installed you will find it under programs with lots of repos
Hi, i am not very techie. I use the Oath repo and love it, thoughbit seems it is going down. I do not have real-debrid, don’t want to pay as limited in funds. I am trying to use other repos that say you do not need real debrid to find links, like the crew. However it never finds any links without rd like the Oath did. Am i doing something wrong? On the repos you list some say they use both (non RD and RD) but i find they never find links that are not real debrid like the Oath or Exodus used too.
I tried stremio, but it does not seem to have trakt library. Or, have i not looked properly. I prefer to have my trakt library favourites, particularly on tv shows.
The Oath, Fen, and Venom all continue to work and will continue to do so for an unknown period of time. Recommended to disable their respective repos and on the video add-ons turn off auto-update.
