Weyd settings? HOW TO? Instruction Manual
I did a 1 yr sub as well last fall. So far I really like it, loads links way faster than Syncler.
Tx @Powerfader I was hoping you’d jump in and let him know your experience. No good me saying much as I’ve never tried it. Again tx.
Quoting ORION: The Orion Panel allows you to search for links, change your account details, make payments, and get support from the Orion team. And provides an API KEY. tiny url is a scraper which is similar. So like KODI extensions that require a scaper so does WEYD. Real Debrid unlocks content. You do not need a paid version of Orion and Real Debrid. Not sure if this unlocks more content but with ALLDEBRID they also use API KEYS.
I have weyd for 3 years now and only get it for 1 year 5 connections. like @Powerfader said I would not get a lifetime sub. Who knows how long they will be around.
I agree with Powerfader. Not sure how long they will stay in business so yeah the 5 devices and so on is what I went with. I did find Weyd works faster than Sycler and made easier on every scale. The only thing I found is that I search out titles as Syncler gives more titles like KODI. I liked KODI because of the many titles or categories available but found it breached my security. Just a personal preference.
One thing is for sure. It’s a lot simpler to pay for Weyd vs Syncler+ and quite simple to set up and go.
Agreed. Scraper was a thing but found it with little problem.
Ty so much for the input :smiley:
I’ve installed 5-4k Onn devices for myself & family. Weyd is playing flawlessly on all but my newer Onn. Everything downloaded without a hitch, many links pulling, but when selecting the links I get a popup saying; “Unable To Play – Debrid Service Returned An Error”.
I’ve uninstalled the Weyd App & reinstalled it several times. It was given permission using *Real-Debrid_Trakt_Tinyurl & Orion scrappers.
Something, a setting, seems to be blocking the link downloads and I can’t seem to find it through many troubleshooting steps.
I’ve even removed one scrapper and installed another to no avail?
Any help would be greatly appreciated. Can’t find any mention of this elsewhere.
Thank You
Jeffrey
Hi this came out Yesterday.
Due to cloudflare security, tinyurl link of scraper on weyd app is now not functional.
Earlier there was two scraper available, Lalit has condensed this down to just weydz
New Scraper url is here for further use
bit.ly/weydz - this scraper have all the thing which is in ongoing development with all sites support like regional site or Anime sites etc.
Weyden is no more further maintaining. so use only Weydz.
These are backups to Scrapers from the post above:
They are the exact same endpoint as his Bit.ly links in the event they are down.
rshor.tk/weydz or rshor.tk/weydx - All sites support like regional sites, Anime sites, etc.
Cheers.
Thank You Explorer for your time. Much appreciated.
You’d think Weyd would post supporting scrappers, but then perhaps there’s a reason they don’t.
They do post to scrapers, but you have to belong to their discord. If anybody posts and they need help, I will try to help them
Outside of that I found prior to this that if your VPN is at one country and you switch the links will not be playable like Jericho said. This happened with ALLDEBRID. I later found out that my account was piggybacked so changed the passwords. Occum’s Razor I have learned painfully. Great you posted the scrapers here. I am weary about reddit and was hijacked on DISCORD. I also after many events stay far away from any app that says free including the KODI player.
They actually post this information on their Telegram app.
Hey Troy,
I am having trouble getting my shows to play on Weyd app. I can play movies. There was shows I was able to watch. They are no longer able to watch. I have Preminnize, all debrid, and real debrid . Help
Go into settings and refresh your scraper. If you’re trying to watch a new show, On Weyd that just aired on TV Sometimes it takes a day or so to get them uploaded. So they will play on your services.
Have a look through here. There’s a lot of good information.
Go into settings> accounts> premiumize and turn off "stream optimised "
And again in settings> accounts> real debrid, make sure that first 3 options are enabled. The fourth option is purely a personal choice.
But I have it enabled as well.
Finally, just ensure that Trakt is authorised and your Weyd account is still active.
Thanks so much
Thanks I will do that
