I would go through the steps to factory reset the box. We discuss the methods in here and you can find that with a quick search of the forum. If that doesn’t fix it, I chalk it up as a biproduct of producing these in mass. A certain number of them will be faulty. If it wasn’t long ago that you bought it, Walmart may just give you a new one free. If not, I wouldn’t worry and spend more than $20’s time trying to revive it, just grab a new one and you will be back up and running.
Yup, think that’s what I thought would be response. I agree. Can’t reset to factory ,cuz it wont boot up after the Google TV appears, just stays blank. Like I said Oh Well 20 bucks,no bigey ![]()
Have you tried pushing the little button on the back of the box?
Thanks for that feedback, appreciated much. Tried that , but that little button by hdmi is a quik pair for the remote. Tried it twice and got pair remote option, but no reset to factory. Only other thing i see on opposite side of hdmi is on/off power light. I will look again ,maybe I’m not seeing that reset button. Any case ,I’ll keep tinkering w/that box as a challenge. Maybe there’s a secret “buttons hold down” for factory reset like there is on firesticks, never know, these devices are pretty much made the same in a lot of ways. For sh…s n Giggles, it’s somethin to play around with
There absolutely is a Factory Reset. some of us here including me loaded the Wolf Launcher and then our ONN boxes bricked. I was about to take it back but then started playing around with the small button on the box while powering down and powering back up. I cannot remember exactly what I did but was able to factory reset it by some combination of holding down the small button on the box while powering down then back up. I believe the answer is somewhere here.
One of the first things I did was put on Wolf Launcher. It works better and and more stable than on my FS 4K Max. There is a reset button as you mentioned. I just got mine a few weeks ago. I’m quite happy with it.
If I remember correctly @SoloWarrior you power down the Onn then hold that button in and turn the power back on and keep holding the button down. Some say for 3 to 5 seconds. Then you’ll get some info on the screen and you have to click the button quickly to scroll through the options. I know there is a you tube vid here if someone does a search for “Factory reset 4K ONN box”.
thanx, I luv it, I’ll be on it !!! Gonna resuscitate this little box somehow someway. Cuz I really do like these puppies. Luv this community, lets keep up the great communication
I’m gonna take this as my new year’s challenge. Be Damned if I don’t “get er done” !!! Tried power down , hold back button 5 sec . , then power back up , tried a few times, but did’nt work. Keepin at it. persistence is the mother of invention or somethin like dat
1:Hold reset button on back of box for 5 seconds
2:unplug the device
3 still holding reset for 10 seconds
4: stiil hold the reset plug the box back in.
Use the reset button to scroll through the listed options
Press and hold to initiate the command
AAAAALLLLLLLL… right, here we go , gonna try again. And I’m gonna pray while I do it. !!!
I’ll pray right along with ya.
Thanx fur that prayer !!! It GOD said yes, but only85%, was able to get the 3 0r 4 options tp pop up left hand corner of screen. But the min. i lift my finger off reset button , options go away. do i need to push that button super fast or somethin else ???
I’m goin back in n tryin again, before wifey brings down the hammer, we gotta get to gettin ready to go- go out to some friends for the Eve. 2 seperate stops,
Hey Miki, Thanx so much, u for sure got the right formula.I’m a master @ bringin up that reset option screen. Now I need to become a master of scrolling down 2 to reset to factory, will try try again another day, next yr. Every time i move off the button just a hair it disappears, can get it right back if i press button quik, just ca’t scroll ![]()
No scrolling, each quick click brings up an option, when factory reset appears hold the button down to choose that.
Nice one Miki…i copied those instructs to my onn 4k folder…i still have 2 of the older and 2 of the newer boxes that are still unopened…saving them for whatever…lol
Nvidia shield
Buzztv 4900(x5 was a turd)
T95
all working great with tivimate,500GB ssd drive and a iptv service and a couple of movie apps…
Would watch the ball drop but we’ll be sleep by 10pm…lol
does’ntlet me quik click, sec I release n quik clik ,option goes away. gonna try it once more, then gonna try takin it to walmart n askin if they"ll switch it out. somebody said they do that ,if it;s in stock
Walmart came thru for me, just switched it out fur a new one ![]()
