I guess I messed this up the first time…
I saw an earlier reference about using a USB-A 3.0 Gigabit ethernet adapter with the 4K Pro. Just for giggles, I connected an Anker Gigabit adaptor to my AT&T Gigabit Fiber account. Gig Up/Down. Using the Speed Test app from Google Play, I average about 720 Up & 725 Down. Color me impressed.
Thanks for the video review Troy.
Definitely don’t need speaker and prefer to hide device
Here’s an interesting bu…“feature”.
Installed my new 4k pro, all went smooth except for one app- the Silicon Dust HDHomeRun (OTA to IP converter/dvr), abbreviated here HDHR.
Old 4k ONN box: connected wirelessly to Network x, VPN off
New 4k Pro box: connected wireless to same network, also VPN off
HDHR installed on 4k Pro (although with same issue as Analiti, needed to open Google Play Store directly to find it). HDHR running flawlessly on the older 4k ONN box.
HDHR app on 4k Pro CANNOT FIND the HDHR hardware on the network !!?
Uninstall/reinstall- no joy.
Solution- use a wired (10/100) connection to the 4k Pro, HDHR hardware found by 4k Pro and app works.
Downside- Internet Speed Test went from 450/200 down/up to 98/96 down/up, later on to 54/97… Yeah, yeah, I know, still totally adequate- but it does offend my geek sensibilities.
And it gets even more bizarre, although probably due to the Internet Speed Test app- when I connect Surfshark, the reported internet speed is 187/189 (down/up. From a 100 MBps port- uh huh, sure,
So WTF does HDHR work with a wireless connection on the old 4k box but not on the 4k Pro box? Inquiring minds would like to know. Film at 11…
UPDATE 1
(1) Got HDHR working with WiFi, but had to use my WiFi-5 wireless router (directly inside the Cox Modem). The issue was that when I connected to the WiFi-6 router (used as an access point), the HDHR registered on the WiFi 6 device with a different IP address (192.168.1.xxx) than it did on the (built into modem) Wifi-5 router (192.168.0.xxx). However, that still doesn’t explain why the older 4k ONN device with HDHR is perfectly happy connected to the WiFi-6 router.
(2) The “Internet Speed Test” app Troy used gets…err…“confused”. Other Internet speed test apps give values in the 70-80 MBps range consistently.
If you figure out how to adjust screen, please let us all know
Scored 2, with the same remotes as Troys. Getting Dolby Vision and playing Atmos through receiver at 1/3 the cost of the mecool plus deluxe. Best bang for the buck. It’s a fire cube/stick killer.
Not sure the issue but I installed the homerun app and it worked. HDHR also works with the sparkle app although its not free.
Might be a bizarre setting in the new 4k Pro box that I’m missing, will further examine in my…err…copious free time.
nice video troy… i have one question though the graph of bench marks you showed was cpu speed, they had a second graph that was gpu for gaming.
Are you saying the cpu speed is also for gaming cause if they are separate then this cpu speed is below firesticks.
i included both cpu and gpu charts for review and/or input for educational purpose for me
Well at least it’s not in the shape of a dang triangle, big stop sign hexagon or some other thing.
I have the Google Onn 4k.
I am very interested in trying this one.
I like the new features and added storage space.
Also I think I have a better understanding of how to keep 3rd Party App. I have to keep reinstalling Flix Vision.
Really? Lucky you. My Walmart app shows it as out of stock. Not available in store, for delivery or shipping.
When they say select stores. they mean it. The device is not in the DMV at all.
I found one.Put it in my cart. I ordered it and 1 hours later before I could pick it up. They cancelled me. Said not avalible!
In my area (Houston suburb), the regular Wal-Mart don’t have them but the local Super Center got 6 and I scored one. It’s a simplistic box that’s great for everything streaming but not great for gamers. BEST $50 for Streaming out there!
I put lots of apps and ProjectIVY launcher. Everything working nicely and still have 20GB of memory after deleting and disabling bloatware.
There is an app called TVSettings that will do this for you. I used it on a friends setup as he also had a TV that wsn’t sized right.
ben9ron, thanks for the info, going to try that app as my original Onn 4K screen size is to big and my TV is to old to have this in the menu setup :grinning:
Let me know if it worked as good for you as it did for my friends box/TV combo I helped him setup. Good luck.
Luv Luv luving this box so far…Thanks Troy for helping us again…
I’m trying the onn box thanks to you Troy and am enjoying it quite thoroughly, I really enjoy , appreciate your input and feedback as well as support of these topics! You have helped me tremendously with your tutorials! Thank you and yes the onn box is a game changer for me!!! Love it
