Here is the thread where Troy talked about turning off USB debugging.
Do you like the ONN Pro 4k? How much space does it have?
Absolutely LOVE it! Comes with 32GB Storage. Plenty for any Apps I need. I don’t record so there’s plenty of space for anything I need. Well worth the $50
Only issue is I found with it is it won’t do surround sound for me. The non pro works fine.
My Pro 4K just became a $50 doorstop. Crashed for the third time since I bought it for no apparent reason. Working just fine last night and this morning the screen of death. No reason to bother with it anymore
Why not return it. In Canada Walmart takes back everything. That being said the return time for some electronics is much shorter.
I bricked my ONN twice from trying to use a Launcher. Very easy to bring back to life
I don’t use a launcher just for that reason. I know it works well for many but to have it do this 3 times in a 2 month period is bizarre. I might just return it and exchange it for another just because this one might be haunted and I can’t exorcise the demons
Returned my old unit yesterday well past the 30 days because I explained to the manager it was a unit specific problem and I just couldn’t return to manufacturer because it was a Walmart product. He saw no problem and I exchanged for another unit. Hopefully this one was blessed at the factory
Just stay away from the Launchers and you should be good!
OK, answer me this. I got my second unit and rebuilt everything over the past 2 weeks. Working very well until this morning when it crashed again!!. Now, MarkxG I did load on Flauncher because that was supposed to be a decent one that worked. Could that be all my issues because launchers don’t play well with the Onn box? I’m sure others out there use launchers and have no issues, why me? Just wondering
My thoughts are, run the box for 2 weeks and see if the crash issue still occurs. Not to be a smarty pants, but the stock launcher basically will offer the same functionality as Flauncher. If it crashes with the stock launcher then the box is suspect. My 2 cents for what that’s worth.
Thinking about resetting it reload some of the apps and running only an apps only page. No launcher. This is my second box in the past 2 months. Thanks for good input
I have 1 Onn pro, 2 newer gen Onn 4k’s, 2 older gen Onn 4k’s and 1 Onn stick. I have installed a launcher on all of them without any issues. I am not sure what is causing the problems you are experiencing, but it isn’t because these Onn devices won’t play well with a launcher. Mine continue to work well with them.
I have two 4k Onn’s that were purchased in December 2023. I have launchers on both of them and never had a problem. Actually, I don’t even use the launcher on my 2nd that is more dedicated to playing with Kodi and Kodi Fork but has a few more apps. I will probably uninstall it.
I have searched but no luck do you know if there’s any way to customize screen saver on Onn 4k max? So far that’s all I miss about fire stick 4 k max
Someone is using my Onn Pro right now but on the Onn NonPro you can go to Settings, System, Ambient Mode then Settings.
It gives some Screensaver options. Hopefully this is the same for the Pro version as well.
Edit: Yes the option is there for the Pro as well.
Want to setup TWO headphones to connect to ONE Onn 4K pro.
I want to have my self and my wife able to watch a video, but be able to control our volume independently.
I might be sight challenged, but I don’t see a listing in the instruction guide for headphones.
