Vlc media player
How do I load content onto it?
This should explain all you need to know.
@Herm Hi
In VLC media player you can do many things, here is a link from wiki how to.
VLC media player
@Matrix Thank you for a great link with some helpful tips.
@Dak7385
You’re welcome. But as you mentioned above TP manual is the best to install and use the vlc media player :+1:
That was very helpful, and thoughtful of you to share. I appreciate you.
Anybody else find they get the best results using the native player with IPTV? I’ve tried VLC and the other one (?) and get buffering in most cases.
With TiViMate I use the built in player. Works perfectly.
I’ve experienced the opposite. I find that native players in apps are not as good as VLC or MX Player.
@carlbs
