yes thats Wolf Launcher. Going to change the name plates to something wooden looking, just been busy.
My donkey must have been on steroids because I had a surprise in the mail today it’s here
Dam…well they did get plenty water when they were here
Yes I love it I’ll have to look for a 56 Chevy belair to put on mine . I have a 56 belair might just take a picture if that’s possible?
Yes, you can use your own pics. Just save them as png.
Thanks sounds good I’ll have to check into it when I get all my house repipe done after that I won’t be able to afford to do anything else but play around with my new boxes
If you ever get your pic loaded and want the custom plates I can bundle what ive made and zip it for you to download. Just holla
Sounds good I like those can’t wait to get started going to try and set some time aside to get it started Saturday and Sunday kinda hectic here right now but need something to unwind with and that might just be what I need right now . Get in front of my 75" and leave me alone except for the dog of course haha
I will have to pm you my email if you want. Thanks again
No prob, I can zip em and give you a DL link.
You might look at Troy’s review of the AM 7. He had an issue with the stock remote but changed the remote connection to Bluetooth and had no problems after that. Your home screen and widgets turned out great.
Yes I seen that I ordered a air mouse/keyohe recommended in another review for the am7and when I ordered the ut8 ordered the package ut8 and remote for a few dollars more. Just have to make the time to set the 2 of them up hopefully this weekend
Well we have you, me, Bigrich and others on the way to join the Ugoos Crew
I still love my shield but hate the big corporate bast. Durds. Love freedom to do what you want with what is yours with the ugoos
I’ve had Ugoos devices now for over 2 years and am glad the word is finally getting out about them. It has been guilt by association with other inferior China made open android boxes but I suspect Troypoint’s objective and positive review of the AM7, along with recent problems on Nvidia and Fire TV will open the door for more people to consider Ugoos as an option.
@TXRon 2 questions: #1. Does the Wolf launcher have a feature customize icons and logos? #2. Can the Nova Launcher be installed on a nVidia?
I can customize my own icons and then import them into the Nova launcher. Does that work the same way with Wolf?
Yes, its what I do. Make your pic etc. Then in explorer copy them to a folder on internal drive.I made one called wolf_pics. Once done just long press say on tivimate, goto config and continue until you have set it up to direct to the new pic. There are numerous settings found within config so take your time.I use mostly .png but .jpg works too. .png is a larger file but better quality and also allows for transparancy(if needed). For sizes you might need to mess with it a bit to work. On my main wolf screen the larger pics are 400x300 or 300x200. The background is set under launcher settings(long press on screen goto launcher settings. Generally I set BG to 1900x1300 but that can be altered.
Not that I know of can you “customize” pics within wolf launcher. Also be aware that certain launchers seem to screw with stability. I went through issues with Flauncher on nvidea.
Been making icons all morning and changing them out on my tablet. Most of these design guys who make the icons make booooring ones!
I have Nova installed on my tablet.
Yep, its more fun to make your own but a little time consuming. Here lately ine been bingeing on the Ozark series and tweaking wolf launcher
