Between those 2 @Miki lists you can get almost any mainstream sporting event. Great when your on the go.
Here is the APK. This is the one I have on my Nvidia and tablets.
I just downloaded it on a phone to check. It works fine and has 102 channels.
Tx @Powerfader. Think I’ll give the app a run on my Max and compare it to the feeds in The Silk Browser. Have fun and STREAM ON.
Works fine with Surfshark VPN as well, but I had to change the city to Chicago in Surfshark and then it works every time with the restricted channels.
Yeah, Chicago seems to be working today, but that can change. One time I connected via India! lol
Yeah, you need to use a VPN
It says for Android, will that work on the Max?
Yes it should. AmazonTV is built on Android.
ustv247.tv has only 75 channels. BUT ustv247.com has 102 channels. This is FYI as I use kodi, but just thought I’d throw that out there. I don’t use either as I’m a kodi guy.
I am using Proton Free VPN (USA Server) on ustvgo.tv via Silk browser and am getting all channels.
Free VPN for Android | Proton VPN
ustv247.tv has 102 channels in the Silk browser on my 4k Max.
I was able to get all the channels when I switched to Dallas location on VPN today. Never experienced not being able to get a channel due to VPN location before. New experience, I will put it in the arsenal for next time.
Using Windows pc it only shows 75 channels and espn and a few are blocked even with Proton plus servers. I’ve tried several cities with no luck unlocking all. But that’s the norm.
Ya on my max I get 102 channels, but of course some don’t work.
On Silk with my Lite I see only 75 channels.
The Max shows 102. But this isn’t anything I use, I have a paid sub and 3 freebies that cover every channel I could want.
Wierd, just clicked direct from your link on my samsung android phone and only got 75 channels. Oh well. No biggie!
USTVGO 247 is a just in case backup. I rarely use it except for when peeps start posting about it. I get all those channels and whole bunch more elsewhere.
Btw, I don’t think the Proton VPN works anymore on the USTVGO 247 app. Although, I do find intermittent success using SS. I find even in SS I may need to seek out other servers because sometimes a server will not unblock those restricted channels. Lately (yesterday) the Chicago server was unblocking them but haven’t checked on it today.
Also, @Tico259 posted the 2 links that one showed only 75 channels and the other showed 102 channels using the web stream. I don’t use the web stream because I downloaded the apk for convenience, but I do have the web stream saved as a favorite on my laptop and made an app/shortcut using the Microsoft Edge settings to place on my task bar.
I tried the app PF, but it buffered like crazy and the stream quality was poor, very grainy. Silk browser is best for me. But like you I don’t use this much at all. My IPTV service is best. With Proton I have to try different locations. Often NY seems best for me.
