USB external drive
I installed an external USB flash drive using the OTG cable as instructed on the Troypoint video. Using the TiVimate app, I selected the channel to record. When I went to select the folder to save the recording to (it showed both internal storage and the USB drive). I selected USB drive however it doesn’t change to the USB drive. Recordings are stored in the Internal shared storage
Hey Tilly…
Is it a split 50/50 drive or regular extrnl?
