Go to about and see what version you ended up with. Whatever you have should be in your apps list.
I ended up with what I started with 5.1.5
Uninstall it and go to the toolbox you can get the earlier version. I know you’ll have to reinstall everything. If that’s what you want. That’s the only way.
“Throttlejockey” when you say “toolbox” do you mean the porocess I just went through? Or, is there another option.
The latest 5.1.5 killed my “Catchup” feature.
I moved my provider list to my “Sparkle” player and my CU channels worked perfectly!
I assume , I haven’t done it yet,that the above mentioned procedure would accomplish the same thing as(how I have always done it in the past) using Troy’s code in Downloader to get the basic app; and then go to your account to upgrade to Premium.
Of course Troy’s way would only get you the most recent version.
I’m going to try 5.0.0, that always worked for me.
BTW, I am going to try all this on a New 4KMax FS 2gen.
When I bought my 4KM FS I actually bought two.
Well, I accomplished what I wanted.
I re-read my above post and wondered if Troy’s code(250931 Downloader) would give me an older version.
Guess what, It showed 5.1.0.
I downloaded it, after deleting my 5.1.5 ver TVM.
Now all my catch up channels are working.
In MY case the issue was NOT with my provider but MY 5.1.5 TVM version .
Thank you to all who replied to my recent posts on this subject!!!
Terry K
p.s. I believe the “Uptodown” thing would have given me the same result as long as any previous ver of TVM was deleted.
That’s what I was trying to tell you. The Troy point Toolbox, 250931. There’s usually earlier versions available for some apps. Glad you figured it out
Thanks"T"
There was only one version available, lucky for me it
wasn’t 5.1.5
