Thank you I will try this😃
Blockquote
You may need to disable the old EPG to get the new EPG source to work.
I don’t think that’s the case. Many times when experimenting with M3U and M3U8 playlists in Tivi I have had a playlist load but would not play. So I would check the URL and try again. Sometimes the playlist is simply dead although the link is good. Depends on the provider and how good they are at maintaining their server and doing maintenance.
THE IPTV OWNER IS THE ONE WHO PROVIDE YOU EITHER WITH M3U FILE,or STREAM CODE, HE PROPOSE IF YOU HAVE AN APPLICATION PLAYER OR NOT, IF THERE ISNT HE WILL HELP YOU OUT TO GET IT DONE WITHIN MINUTES, PERSONALLY I HAD AN AMAIZNG EXPERIENCE WITH **********.ONLINE THEY HAVE A N EXELLENT SERVOR AND THE SUPPORT IS JUST AMAZING;
Please do not name unverified IPTV services in open forum. It violates the rules. Tx for your understanding.
That is because it is a locked category and not open to the general public. Discussions regarding IPTV are not allowed in open forum.
how do you install that app?
