Tivimate & error messages
Hi Guys,
I’ve a problem with Tivimate in that I am receiving error messages code 401 and if I try it with a VPN then I get a code 403 error message. I signed up for Tivimate a couple of months ago and it worked fine initially but now I can’t get anything to work. Any suggestions what I can do to get up and running again please? cheers
Talk to your provider. Your sub is probably up.
Thanks for the reply but that is not the issue
I can, bet its your subscription with your iptv, those coses typically mean errors on there end, usually subscription time.
Tivimate is just a player. Its your provider or your internet.
Did you try another app to confirm it is tivimate issue? Smarters or xciptv? You try credentials in a web player? Most better services have one to use.
Sounds like an iptv issue. Try force stop and clear cache on your Tivimate app. If still no joy. Try rebooting your device. If still having issue unplug modem, router, and devices for about 10 minutes. If you are still having issue. Then I would contact your iptv service.
You may also want to delete out your credentials and re-enter them, on top of what @Powerfader mentioned above.
& maybe try the free Pluto url in Tivimate
that’ll show u its not tivimate
hth…
if I get that code 401 or 403 , i get a hold of iptv provider they have always resolved the problem,
Thanks for all of the replies, pleased to say it’s sorted now
Could you let us know exactly what you did to resolve your issue? That knowledge will help others. Tx.
I had error message 502 for two days. First thing I did was check to see if Pluto list would work…no problem. Then it was obvious it was the iptv provider. Went into my account and noticed it was expired. Hum, I have monthly autopay, so what gives? Turns out my bank stopped the payment last month and I had to talk to fraud department to get them paid. Of course I had to sign up again with new credentials, but it started working within 15 minutes.
I have a lifetime account with Tivimate. I have had it for several years. For the last two weeks the screen freezes but the sound continues, happens freequently. I have also been getting the following message -
RecognizedInputFormatExeption. I have completed all maintenance as in unplugging router, Firestick 4K max, cleaning out cache, restart etc…
I did not uninstall Tivimate but did remove the playlist and re-entered the url in extreme codes. I lost all my favorites doing this so I am trying to avoid losing them again. Can anyone help or give a suggestion on how to stop this message RecognizedInputFormatExeption happening. I am not sure if I am allowed to say the IPTV provider I am using. Does my problem sound like a tivimate or IPTV problem. All other apps are fine. Thanks in advance for any repsonses.
Probably provider issue.
I’m starting to have trouble with a lot of buffering from my provider that I didn’t used to have before. I believe that because all these places getting shut down they may be running out of feeds. Or or the problem is with my provider. When I used to joke about my 4K whipping my never Shields butt, now my 4K is acting just like my never Shield takes 10-15 seconds for the channels to engage a buffers until the channel’s engaged sometimes they don’t engage it’ll try to connect five times and then I get a 404 then I start switching around channels it’ll start working again.
Provider issues on your end… My service remains flawless. They stopped allowing trials and since it’s invite only that means they stopped accepting new subs and that is a good thing
Yeah probably provider issue or a VPN issue I’m still having issues with the surfshark on my end. This morning I had to watch all my recordings on DirecTV. Sorry guys I kept it for my wife but I had to use it this morning for as a backup. It’s a lot of damn money but at least it works.
Good for you!
