Tivimate & error messages
Get your self an additional iptv service
Especially one that encrypts streams. No vpn needed then
No need for backup direct then.
You’re speaking to the choir on this issue. I do believe the latest update with SS VPN that is the issue. I had absolutely no problems until the update. I believe some of the problems also with the IPTV provider. Two wrongs don’t make a right. I’m losing connection speed with SS just recently. Also the IPTV provider with VPN disconnected I still got issues.
Sounds like it’s a good thing I never jumped on the SurfShark bandwagon. I just posted that info as it’s from their official site. Hopefully someone finds it useful.
Yeah I bought the 3-year SS, and I had a lot ups and downs mainly trying to get reconnected after the kill switch disconnection. However for the last five six months it was working really great especially on my 4K Maxx smooth, quick. But since that last update I’ve been getting a lot of buffering both from my IPTV provider and the SS slowing down my speeds. A lot of tickets for my provider, a few with SS, it really helped me with the DNS numbers but lately have been having problems with this new update. That information you provided it’s really good!
And as far as the choir, I just speaking of my equipment my providers! LOL
All good @AJS1. I have noticed a significant increase in problems since the last update. Fortunately they do seem to eventually resolve any issues and put the problems in the rearview mirror.
Hurry Up & Wait ;-(
Anyone had problem with xtreme code login on tivimate where it will process login on one device but error on 5 other devices processing playlist. Unplug the good one but on identical devices it won’t process and do have 2 connections .
You can only have five devices registered with t i v i m a t e! He’s got more than that it won’t register
I have a year and a lifetime and understand that. Not my problem though .Tivimate does give you the choice to replace a registered device with a new one when it detects a new device on install if you already have 5 .Not only Tivimate but ibo media player does the same with this login .only thing is I can’t get it to work in smarters Ibo tivimate only on one certain device with tivimate .
You can 10 devices with tivimate or more but only 5 can be registered at one time. I regularly swap between devices. Lets say you have firestick 1 and 2. I call the name for one of the five registered devices fs1/fs2. When I active fs2 fs1 is no longer active. I can swap back and forth between them at anytime. Just can’t watch both at the same time.
Thats what I do but I do have the ability to register 10 because I have two accounts until the yearly one expires. My son gave me his lifetime .
I wanted to add this to this topic instead of starting a new one. 4k Maxx fire stick, t i v i mate, IPTV provider. The units working pretty good now I have some issues earlier, however if I do get a channel that is buffing about ready to throw a code, sometimes I can clear it by backing out of it going back to the main page homepage I should say go back to channel it’ll kick it’ll engage right away. This happens quite often. Anybody else experience this? Thanks
I don’t know where this inquiry should go.
Has anyone else getting/having an issue with Netflix running on a Fire Stick?
Terry K
I currently have TiviMate on 5 devices, and recently I’ve found that I’ve switched all 5 devices out to ONN 4k or ONN Pros. What is suddenly annoying is that many times I wake up one of the ONN and TiviMate wants me to log in – happens on all the ONN devices whereas before it would keep me logged in.
Is it possible I’m still registered on my decommissioned MeCool or Cube media devices I no longer use, and thus it thinks I’m using more than 5 devices? If so, how do I go about deregistering those decommissioned devices?
I haven’t done this in a while, but if I remember correctly, if you exceed the limit of 5 devices, it will pre-warn you to manually deselect a device. It will not immediately log you out.
Have you not got the TiviMate companion application on your Android phone to check what devices are connected to that current account?
I believe you can check this on their official website, tivimate.com.
Have you recently updated to the latest version? Have you tried using previous versions to test if the issue still persists?
Latest is 5.1.6; test if you have the same issues below.
TiviMate Downloader Codes:
Latest version: 272483
5.1.6 - 272483 - 12.0 MB
5.1.0 - Kanal - 11.8 MB
5.0.4 - 893586 - 11.9 MB
4.7.0 - 366972 - 10.8 MB
4.6.1 - 278077 - 10.4 MB
4.5.1 - 127188 - 11.6 MB
4.4.0 - 721551 - 11.3 MB
4.3.0 - 522324 - 11.3 MB
4.2.0 - 191081 - 11.2 MB
4.1.0 - 13352 - 11.1 MB
4.0.0 - 19237 - 11.0 MB
3.9.0 - 34745 - 10.9 MB
3.8.0 - 41201 - 11.0 MB
3.7.0 - 77923 - 10.9 MB
You can login to Tivimate website with your credentials and remove any device that is associated with your account.
Thanks, I completely forgot about the companion app on my fire tablet (that I use for a Kindle reader). Thanks. I’ll check the version too.
Thanks. I’ll try though the companion app first and then check out the website if needed.
