so this noob thought by purchasing tivimate i was getting what was showing in the post about it. when i logged in i come to find i have to add playlists? i don’t have any of those. can anyone help me, or should i just get a refund before my 7 day trial ends?
Tivimate requires you to load a playlist into them. It does not provide you with any channels on it’s own.
You can find free playlists here. However, it is against site rules to go after any unverified IPTV services. You won’t find much help here if you’re looking for that. ![]()
As far as your refund goes if you bought just a month sub then I personally would cancel it and buy a lifetime sub. Still the best and most reliable IPTV player app out there IMHO. There have been others who attempted something new like cloud syncing, but eventually, regardless of positive advancements at first, they all become either unstable or simply to awkward to use, with constant failures even with their cloud servers. Again this is my personal experience and opinion.
Not a fan of TiviGlass any longer Miki?
Absolutely not. Done with it. I may go back in a few months if I hear of fixes that work. A real shame.
That’s a bummer. I had mild hopes for it over tvlok.
I’m really liking it, and the updates & fixes have sorted it for me ![]()
Good to hear it. Glad it works for someone.
Tvlok is kicking a** now. Many many updates.
tvlok is the only one that comes close or maybe even surpasses tivimate. I broke down and bought the lifetime, hoping he’ll develop for apple.
Ipad and iphone are available now in beta. Appletv is planned
I have to agree with Miki. So much potential but they have issues to fix. An example, I don’t know what changed, but my TiviGlass started buffering a lot. Switched over to Tivimates, same channel, same service and plays perfect. So I’m back to TM for the time being.
Real Tivimate is an IPTV player ( includes no service) - this is what you downloaded / installed
To keep this site safe, we cannot discuss unverified IPTV service providers.
You will have to use search engines to find sites that test and compare them.
Ask for trial to test to include content you want, you will be given info on how setup Tivimate
You may want to give it another try since the early beta there have been many fixes and new features.
You mean tvlok?
Yes sir. I am sure mr tvlok would let you try again without a credit card.
Tx @hotwheels . I will wait until November. Only because I will be traveling for a month and only be able to focus on internet stuff when, and if, I can get good internet. So not much TV watching. But tx for the suggestion. Have a good Sunday.
What did I miss about tiviglass @Miki ? You almost had me talked into trying it. I looked at the other thread, but saw nothing.
Way to many things going wrong on it. I deleted it off all my devices to take a break from it as it, like TVLok, is getting way to frustrating. The things that don’t work are numerous and yet seem to not be to the devs. Searching on both is useless. Constant false returns, failure to find actual channels, inability to add found channels to my own groups, options that are there one minute are gone in the next update, EPG search is a total mess, and the list goes on and on. So I’m going to wait for a couple of months and see if these two actually get their acts together and make a player that works. I don’t get a single penny from the hours I spend testing them and pointing out issues so now they just give me a headache from frustration. So I will stick with TiVimate that works.
