TheTVApp in Kodi is not working
What r u using? Kodi or browser
For all the folks writing back n forth I inabled the tv-app back up . Thanks for quick response
Kodi addons the tv-app not working only through browser
This is for the tv Tap not tvapp
TvTap was renamed TvMob a couple of years ago.
Yes ! It was once called TV Tap .
Not working on my end either maybe they should’ve have touched it. Why cant i view it on the browser anymore?
It works on my browser Edge on my laptop and TVBro on my Shield.
TTVA
Go in browser n delete cach. Restart device
Not on the firestick browser its not. It works on my computers and phone. It use to work on my firestick
Ok ill try that thank you
I tried that. It says
Sorry, you been blocked
What browser u using n r you using VPN?
I use Android I actually watch the TV app on my phone through Chrome. Sometimes my IP provider messes around with me too so what I do is like clean the cash out of my surfshark VPN and then I change to the fastest I’m in New York so I do the fastest in New York see they have a service night with surf shop that you get your own number your own IP number or where’s sharing IP numbers when you use a VPN and a lot of these numbers get whitelisted so if I’m having problems I change my IP address it’s just become a pain in the neck lately
Well Diggz Xenon just updated and they removed TVApp from the build’s tv section. If it is there its hidden in a repository somewhere. So maybe a fix isnt coming to Kodi or it’s going to take a while.
I use TVBro, which can be downloaded from the TP Toolbox, and my search is Google.
I use this on my Shield Pro and haven’t experienced any real down time.
Edit: I just checked TheTVApp on my Shield and everything is working great even with my VPN active…which it always is.
There’s no point in fixing it if the developers of the site are just going to keep changing the streaming encryption
Exactly I just disabled it until I hear it’s back just incognito through silk I watch it through there but I really do agree thanks Paddy
Updated to version 420.6 yesterday and is working again.
Thanks for the update. Checked my addon and it updated to 420.6 and seems to be working well so far. :crossed_fingers:
