TheTVApp in Kodi is not working
I am running Kodi 20.2 NEXUS on my firestick, and have had TheTVApp addon installed for IPTV , it was working perfectly fine for about 2 weeks and now nothing will connect. It gives me the full listing of all channels but nothing plays when I click on a channel. I have uninstalled and reinstalled, restarted firestick and it’s not working. Very frustrating as this was the best addon I found for not cutting out or buffering. PLEASE HELP and thanks so much
Is there something I need to do? Still not working. Thanks
I just updated TheTVApp using the Diggz Repo v0.3 on Kodi and it work for a few minutes then started freezing.
My advice: try using TheTVApp on Silk/TVBro until things are fixed (with a VPN).
Watch it on a browser.
i have tried watching with tvbro on my sheild pro is there away to adjust the picture size because it is way to big for my tv screen
Settings>Device Preferences>Display & Sound>Advanced display settings>Adjust for overscan
This will do it for everything, but if it’s just TVBro then I’ll have to research that. Try Webview in TVBro settings.
Have fun and STREAM ON!!
thanks Miki i will try that ,can not seem to find webveiw in tvbro settings
I’m getting the same issue with all the live tv apps on kodi
Live TV on KODI has always been hit or miss mainly because it’s Free so a lot of dev’s don’t fix issues or are slow. They are unpaid Hobbyists! Best bet is to get a paid IPTV service
Are you saying to do this within Kodi? I can’t find the device settings you are speaking of. Thanks
That is in the shield settings.
Ok I have no idea what or where that is. Thanks anyway
Ya the pister was talking about the Shield Pro, so if you aren’t using that device it won’t be applicable to you.
Started Saturday where is just won’t play anything. It says working when you select a channel but shows nothing. Website works ok but app is dead for me. I have the latest version.
Any ideas?
Works on my Shield Pro using TVBro.
Btw, what app? I didn’t know they had an app. Could you post a link to that app?
Thetvapp is working great with a browser
https://mrgsi.github.io/glive/
That is a link to a zip file. So, I take it this a Kodi addon?
Btw, if you backout the /glive/ you wil get these zip file also.
Here his github page.
GitHub - mrgsi/mrgsi.github.io: ZIP files for G-Man’s Kodi Repositories
repository.gsource-2.1.0.zip
repository.topg-1.6.2.zip
repository.glive-1.2.0.zip
repository.gscribe-1.3.0.zip
repository.gsports-1.3.3.zip
repository.freeg-2.0.0.zip
repository.allanime-1.1.0.zip
repository.cartoonking-1.0.1.zip
repository.gtube-1.1.0.zip
repository.dirtyg-1.4.1.zip
repository.wnt2-1.0.1.zip
repository.jigsaw-1.0.0.zip
repository.alpha.yt-1.1.0.zip
The TV App Kodi addon is still not working.
