No I haven’t.
Apparently the buttons are there for show or were not added to the software…
Hopefully if they decide to have an update they might include it…
Good Luck
No I haven’t.
Good Luck
Yes, I would like see the link made public also. The reason I am getting these boxes is that I do not have very much $$ to throw around. I am unemployed and can’t find work. I understand the supporting idea, but I just can’t afford to right now. Things are tight as it is.
If that’s the case, get the ONN box from Walmart…
Easy setup and the control works on the tv…
IMHO
Good Luck
Hello,
PRESS AND HOLD THE BLUE OR BLACK POWER BUTTON on T95Z (upper right on remote…Flash led starts) UNTIL THE LED STOPS FLASHING.
THEN EXAMPLE PRESS THE VOL UP ON T95Z (Top one upper T95z remote)THEN POINT AT REMOTE FOR TV THEN PRESS VOL UP TV REMOTE AND LED WILL BE ON SOLID . DO THE SAME FOR VOL DOWN VOL MUTE AND POWER BUTTON.
Sorry, but that didn’t work for me…
I’ll keep trying…
Thanks for your help…
i had no issues. On the t95 remote you have the power , vol up,vol down and mute button together top right side of remote.
Press the power button and hold and yellow led will flash keep holding until it stops flashing. Then point T95 remote at your tv remote (front of each remote must point close to each other) then press the power button on tv remote until you see yellow led condition change. Repeat for all the rest of functions.
First off the light on the remote is red…
After holding down the power tv button it does turn solid red, after hitting the volume up button the red light starts flashing and then shuts off.
I’ve tried 10 times already and nothing.
I have the latest t95z plus box with the 128g memory…
Thanks again, I’ll keep searching.
I have also new unit Jan 2024. Should work for IR remotes and not Bluetooth remote. My sequence description to you might be off. Press and hold power button t95 remote until led is solid then press vol up t95z until led flashes point both remotes together and then press vol up on tv until it stops flashing . Repeat for all functions available
Didn’t work.
Thanks again
Thats still not an answer to my question. I have already bought the T95Z plus.
What question?
You must have me confused.
If I were you I would get the ONN box from Walmart, if you need help there are many posts here to help you…
Let me know what happens…
I just received the T95Z box and getting it loaded. Played some items. Downloaded most of the items I wanted. I personally have had 0 problems so far. It has not crashed or locked up. I got it off Temu for $35. I am going to get Diggz loaded next. I also got a little cheap keyboard because I wanted a back-lit key pad. Well, the back-lit doesn’t work, but the functions work awesome. It is better than expected. Another toy from Temu out of the bubblegum machine!
What usb fan do you recommend for T95Z
AC Infinity S4 multi speed fan, $15.99 off Amazon. I put them under all my android boxes and they work great. Very quiet.
Thank you Sir
I followed @sim_bill s advice and got two of those fans. One for my Shield Pro and one for the external SSD. Don’t know if they were absolutely necessary but for that price an ounce of prevention and all that. Tx Bill. Have a great Sunday.
What I like about this fan is the overall quality, price, multi speed switch and the quiet operation. On the low setting, I can’t hear it at all.
The one I got also has a 3 speed switch and an extra usb plug on the cord to charge stuff. You’re right, i can’t even hear it on hi. I love the rubber pads top and bottom for no vibration. Well built product.
Fans? Guess I lucked out with my 6 year + old T95Z boxes. No Fans, never shut em off.
C’mon @MarkxG we all know you got fans here, and more than 2.
