I’m using Syncler+ and removed RD and added Premiumize. I’m also using Surfshark.
While I’m getting a lot of premiumize inks… When I go to play them… They take a long time to start playing. Anywhere from 1-3 minutes. I’m also getting some buffering when playing.
Are there any settings to fix this or is this the new normal?
I tested every single server and switched my VPN to 6 different locations throughout North America and my speeds were from 141 to 151 Mbps down. Not a whole lot of difference. Same for Ping and Jitter. Ping seemed to vary the most.
Greetings: Syncler has not been pulling sources for the last two days. I am in the US, but I also have received messages that friends in Canada are experiencing the same issue. Does anyone know how to fix this? I am using a ONN 4k on one TV and an ONN Pro on the other. I am using Surfshark, and I have offloaded and reloaded both Real Debrid and Trakt, and I have tried three different express packages, but still no streams are being made available. Real Debrid is working on other apps, but Syncler just doesn’t show any streams. Can anyone help? Thanks
Dear Premiumize admin: Thanks for the update…Would you be will to finally reveal where your servers are located…? Or at the very least that you are NOT located in Western Europe…?
Thank you…
