Syncler+ & Premiumize slow loading
Twitter/X
Real Debrid has ceased to work for Cached Torrents, please check the forum as this has been discussed over the last 36 hors extensively
Thank you for your help, Canonbenny. I saw some of the discussion, but I didn’t understand that a Cashed Torrent related to Syncler. I remain somewhat confused as to the recommended replacement for RD. Do you have any suggestions? Again, thank you for your help.
One of the replacements is in the title of my original post… Premiumize.
Troy has addressed this in his post from yesterday.
A workaround for RD at the moment is:
Choose a show/ movie> play.
Let the links finish populating. Assuming there are no playable links> go up to the magnet icon> click on it, and it should provide you with some links.
Choose one with plenty of seeders. Click on it> it will say " adding to your cloud". Make sure above the links you choose RD.
Either click on it when it is finished, and it will play…OR…
Go into debrid manager on left of Syncler home page> debrid manager > click on it and your download is ready to play.
This process is not recommended on beta version, because it crashes every time you try to add a magnet to another show/ movie, immediately after the last one.
The menu in adding a magnet, shows the debrid service you wish to add to.
After the first time you add a magnet, this menu is no longer visible.
You have to exit the app, force stop> clear cache>reboot and start again.
I have logged this as a bug with the dev.
But, your download will sync with your debrid manager in both versions.
So you could switch to beta, if that is your choice, and watch it there, from the debrid manager.
However, this method does not mark the show or movie as watched. You have to do that manually.
There are other external ways to add to your cloud, through certain apps.
But I’m not sure i am allowed to post them or the procedure on this forum.
Good luck
Thank you, but, given my lack of Tec acumen, I think I’ll go with Premiumize. Troy’s presentation was very helpful.
No problem. I was offering another solution. Premiumsize is great for me.
Thanks again!
You can get a 7 day free trail of AllDebrid. See how that goes. Juts be aware it can take upto a couple hours to start pulling feeds. You add your AD account details in the settings menu of Syncler. AD cots about the same price as RD. I have done this and its working well but I have also paid for a Black Friday deal on Premiumize as well, so now I have them both added to Syncler. See how you get on with AD for starters, any questions please let me know :slight_smile:
If your using Premiumize I have read that if you go into premiumize settings and change to cloudflare server it helps reduce buffering. Its worth experimenting with different servers however I personally find leaving it on auto gives me a faster connection speed. It will be down to your location and the server you are using in premiumize which will give fast or slow speeds loading links
I just switched to premiumize due to the real debrid. It seems to be slower and I don’t get links that work especially asgard which is my go to most of the time
I use a vpn and same with firestick 4k and google chromecast tv and tablets
Anyone else same problem
Thx
Go to your account page and use the Speed test…about 10 to 15 sites will drop down on a list and you must pick the fastest…it’s a bit pf a pain but the fastest test will be the one for you to pick…The “auto” pick is not good…Auto is usually not the quickest…I had the same problem as you…but after a speed test on the account page I never looked back…They fastest changes a bit sometimes so I do that test about once a day…The San Francisco (Roubaix) seems to be the best for me…good luck…
Wow Ty I’ll try it!
I did get to increase the speed and on my 4k firestick I did notice a little change, with Asgard in particular tho I had to re authorize to get it to work
On my. Chromecast none of my add ons work I don’t use a built, so I may reboot and start over.
Trying my Samsung tablet next!
Ty
Hi
You can change the Server location in settings, instead of Automatic
May help…
Did anyone sign up for the black Friday two year special for $109??? I have entered 3 support tickets with no response asking if I could upgrade my subscription with no response.
I bought the 3yr deal for $139 and it was applied to my Sub within 30 minutes.
I bought the two year BF deal - then afterwards, realized (though I’m not sure how I missed it) there was a 3 year option.
Really quick.
Hi,
I have taken a short sub from Premiumize to sample it and it seems to get good links. The only problem for me is I can’t play with the standard Exo player - just get an error message. This worked fine with RD and is much easier to use than the other players. Has anyone else had this or have I got a setting wrong?
Can someone please explain a step-by-step how to setup premiumize with syncler? I bought the 3 yr sub of premiumize and when trying add to my syncler+ account I get a Failed to retrieve device code. Ensure the service and your device both are online and try again. (message)
Thanks
