Syncler info please read
Just not my day. Still not working. How do I go about getting it to work?
I would start with the normal restart modem/router, restart device, try a new VPN server, clear cache/close unused apps, re-authorize RD, etc etc and see if it works. If that doesn’t work it may take a full uninstall/reinstall of Syncler, but I wouldn’t do that until you are sure.
Ok. Cleared data and reinstalled all. Back up. Thanks all for patience
TP-Dracoo,
Do you still need Real-Debrid when you subscribe to Syncler? Do you get a lot of quality sources? Thanks.
Dracoo can answer you, but just my thoughts. You will get sources using the free version of these streaming apks without RD, but like Kodi, it will be inconsistent at best. It will never include ultra-quality sources, either, that give you the best audio and video quality. Real-debrid is such a value for the cost, I can’t see why anyone wouldn’t go that route, but it is possible with a lot of patience.
No, you can use the free one but you wont get as good links without RD.
@AMD237
Correct. I use Orion with my RD and use that into syncler.
I do as well…Syncler is spectacular with this combo.
Love Syncler with RD.
Thanks Gentlemen, I appreciate your timely response.
I’ve renewed my license twice now once for 6 months and once for a year. Never had any issues. It says your license is expired then you just add the new one not sure what other people are having difficulty with.
" I use Orion with my RD and use that into syncler"
I use Syncler most of the time and find it really good and very reliable. I’ve installed both RD and Premiumize. I also subscribe to Orion but just cannot use it on Syncler. Could you point me to some guide or instructions?
You need to go to orion panel, you can setup RD and premiumize into orion and use orion as a package provider
Please keep all syncler payment questions in this topic. I have seen so many topics asking the same questions. Let’s keep it here. That way you can also see my setup guide and important info. I hope this makes it easier for people. I will pin it too. That way all your important syncler stuff is here. Please, before you ask on payment please read all the info!
Updated guide
My annual subscription expired and I wanted to re-up for another year. I went through the process as I have done for the past few years, but it seems they must have changed the process, because they now say something about “you will not receive an email with your code” but have to obtain in on their website somehow. Has anyone else using Syncler+ noticed this change? And how do you fix it?
I followed their instructions to pay via cryptocurrency (Coinbase/Bitcoin), and everything seemed to work well. I even got a summary screen (which I took a screen shot of) from Syncler+ showing that I paid the fee. But I can’t find anywhere how I use the purchase code to access my code for the app. Their website is pitifully short in the user friendly department. Can’t find any way to contact them directly and ask for help.
Anyone have similar issues or have any idea on how to help? I would be extremely grateful for any help.
Thanks in advance!
Please read the topic about payment, we can also discuss payments here openly. When you pay with crypto on coinbase with syncler they email you a key. It’s sent with your payment details to the assigned email you registered with. Check all spam and junk folders.
I am not sure about email @TP-Dracoo. Here is a quote from their page.
I have not received any email.
For improved privacy we do not store your email on our database. Only a cryptographic hash is stored in our database. For this reason we cannot deliver you your codes via email.
Yes, thanks @Miki you receive info to login to synclers data base to get the key info. That is what i ment and should have been clear on. I will update this with that info
Tx TP. I’m trying to follow along and understand the entire process. They do have a tracking page for anyones order. Have a great day.
Syncler direct should start offering payment using Amazon Pay. If Real-Debrid can do it why can’t they?
