I’ve never used Syncler and have been using KODI for almost 8 years. Seems to be lots of problems with that Addon. But regardless of that if you are having problems with ANY Addon just find another one that works. They ALL do the SAME thing. The Crew, Homelander, and Umbrella are all working. I suggest using one of these.
Try it without using your VPN. If you have Real Debrid, you dont really need a vpn.
I’ve been using Syncler for over a year and never encountered problems.
Sure, the beta version has had some hiccups, which are being addressed. But the stable version is fine.
Depends on the device being used/ set up correctly and sufficient internet speed.
Did that however it still did the same
All i can suggest is:
Settings> force stop and clear cache.
On your devices, clear cache and make sure no apps are running in the background.
Try JustPlayer and see if that helps,you can get from the Google Play Store
I love this. I’ve had this for multiple years, always had great experience with it
I appreciate it.
G’day mate welcome
I have tried to install using Troy’s instructions-but Syncler will not install! I get as far as Troy stating to delete installation, I press delete. I go to my home page and no Syncler app! Help!
@mgier Scroll down on the link and click on install apk.
Good luck. Unable to respond to anything else, due to not being a patron and 1 post daily limit. If you’re stuck> send me a PM.
Edit. I saw your reply but cannot answer nor send you a PM.
Try again that sometimes happens. I have just done it and it worked 2nd time. As long as you are not using a firestick with OS 5 or less.
If you still have issues, raise it on Discord> support section.
https://discord.com/invite/kZFt6TD3QZ
Additional Edit:
Again> I cannot reply due to my membership status.
This is a far better vendor:
https://magnify.pages.dev/vendor
Use the main pkg
If you need further help, send a PM.
Note my comments on Firestick restrictions.
Thanks-says file is damaged!
I was able to install Syncler by going into downloader and deleting all the syncler installer. But now, as I follow Troy’s instructions to add the 3rd party vendor or jackedup.com/syncler/vendor it just keeps loading-going on 15 minutes!!! What have I done wrong–granted I know nothing about tech. But I did have Syncler for a number of years, then a few days ago it just disappeared and I had to readd to my firestick. I know I did not have these issues prior. I was able to install Track and RD with ease! TIA
