Surfshark settings for NVIDIA SHIELD & Fire TV Cube
I read the best settings for a PC.I’m wondering would they work for The shield and Firecube?Thanks.
I have tried all VPN protocols with Tivimate and even turned off Cleanweb.It just won’t work???Is there another setting I’m missing?
Whats the download speed with and without vpn?
862mbs down and 148 upload.
Should I delete Ipvanish from my shield?
Whats the download with vpn?
Its worth the shot uninstalling IPVanish to see if it helps. Easy to get back installed if you want to.
188 down and 57 up with wireguard.
Great speed, Try switching to the new york server.
I’m in Canada and was hooked on to Montreal.
It must be a setting.It works fine with Ipvanish.
When you say “wont work” what exactly is it doing or saying? Assuming you have cleared Tivimate cache, force stop, etc.
I will double check this now.
Kodi and Real Debrid works fine.
Is this a new IPTV service?
It’s about 6 months old.
But you just switched to SS correct? And it always worked with IPV…
Yes I just installed it and it worked fine.
Tivimate is giving me an error code 456.
Hey @chuckman If I were you, I’d go ahead & uninstall IPV…then I’d uninstall Surfshark…reboot your Shield…reboot your Router…install SS again…set your protocol to Automatic…jump on the New York server…run an Analiti test & see what you get.
