Just purchased surfshark after reading about it in Troy’s review…
I watched his video on how to install it on fire stick and it was very helpful, however there is one thing I don’t see referenced in the video and that is this…
Can you select individual servers within the selected location???
I used to have IP vanish and if I selected Chicago for example there was a listing of all the individual servers in the Chicago location to choose from.
Does surfshark off of this selection option?
Do you know if the “Invisible to Devices” feature is the same as Local area Network (LAN) in IPVanish? Asking because I like to record sports in Tivimate to my laptop.
Thanks, Steve
At some point you will, not all vpns work with these apps, some do some dont. These are major apps like prime netflix etc… they dont play nice with vpns, this has been discussed at length.
SS calls it “Bypass”. Turn that on and choose the app to Bypass. (Features tab on left of VPN menu, scroll over to right and it is under the CleanWeb option)
I’m a big believer in ExpressVPN as well. But Surfshark has really knocked my socks off.
The Clean Web option was already turned off, when I checked it. That’s something the tech support guy told me to do. Didn’t make a difference. Can’t figure out why the fastest server that SS recommends, wouldn’t work!!!
Yea, the “fastest server” automated system doesnt seem to work correctly on any VPN. That connects me to St Louis, Mo when Detroit and Buffalo are right next to me and are so much faster and more stable (I’m in Ohio).
Find the best server that works most reliably for you and set it as the default under the quick-connect and auto-connect options. It will always go to that best option for you.
