So when you look on the Onn under scrapers torentio is enabled? If so what I would do is force stop the app and clear cache while you are in that spot and then open it again. If you use Projectivy launcher hold down on center button and a pane will open on the right and you can go to app settings to force stop and clear cache.
That did not work . Should I maybe turn my box off fir a minute ? Torrentio was enabled . I went to setting on the box , went to apps . Then I clicked on strmr . Hit force stop . Then cleared the cache . Wen back opened strmr . No sources found for the couple movies I looked for .
I would try it but I have RD, TB and Debridio, no Premiumize set up.
What happens if you turn the comet scraper on?
Can you copy and paste in to the box from your phone?
Here is mediafusion link in the scrapers section add it in the space at the bottom and click the Plus sign.
https://mediafusion.elfhosted.com/manifest.json
I just turned on only torentio and it seems to find enough links to auto play the 3 movies I just tried.
I am at a loss on your set up especially if it works on your phone.
I may try unplugging the box and heck maybe even the router and firing the router back up before plugging the box back in.
I have quite a few of them, not as old as them, but getting there.
Glad it works for you.
Go through the Duck Streams guide.
and pick manifest instead of stremio when you get to where it is time for your user and password.
once you are done , copy that URL and put it in the custom scrapers section below Comet.
Thank you. I copied the url on the computer set up and then emailed it to myself to get it on my phone. Then used google tv to paste it. The app is working great for me. Better than Stremio. The only thing not working on âhomeâ in the app is âcontinue watching, movies or showsâ. Should it be showing?
I successfully installed Duck Streams to Strmr. Do I need Torrentio & Comet enable anymore? Is Duck Streams enough? Thanks
It shows up on mine. You could try going in to settings, lay out, then Home at the top and see where it is? Maybe it got toggled off, or maybe try reset to default, and adjust from there.
I do not have them enabled in mine, it will work with only Duck Stream. Try playing around with it and see if it makes much of a difference for you.
I love Duck Streams. The only thing I donât like is the coder/suppliers name is not shown. Torrentio and PM took a big jump over the weekend and now has even listings of 4K, 4K HDR, and 4K HDR 10+. So hopefully weâre over the problems. I donât like that STRMR has no way of making your own favourite list but relies on Trakt which is a pita.
Yeah mine too
Appreciate you
Awww thatâs a shame. Honestly I rarely use it for the two reasons I keep saying. No way to favourite and no way to make your own library.
I never even tried STRMR. Just the Duck.
Kodi #1, Stremio #2 and I donât need ANYTHING else for VOD!
Continue watching showed sometimes but most of the time it does not. When it did show, it did not continue playing where left off. Started from the beginning. Not liking the app for now for this reason.
hello Miki what do u mean by playable streams?
Umm gosh I really donât know how to answer that without coming across as being ignorant or dismissive. So please accept my answer as being non judgemental. A playable stream is just that, playable. In other words you click it and it plays vs. a non-playable stream that when you click it, it wonât play, or causes issues you hadnât anticipated. I hope that helps.
Troy, thanks for you and your team for all that is put together to help people understand and be more tech savy. I am a programmer and it specialist . I became blind after colege and had a family member who spent about $150 on a jailbroken firestick . I looked into it and immediately was enlightened by your information on jailbroken firestick about how easy it is. Being blind has been a real road block in the tech world and you have been a big help. thanks.
