Ok. I will leave you to resolve it. Maybe you shoukd contact Trakt.
Stremio do not get involved in add on queries or Trakt issues.
Yes or it wouldnt be updating my trakt history or progress without the trakt addon.
Maybe I will try adding the addon back but it didnt seem to have the features I wanted.
It only shows trakt watchlist on recomrndations in stremio.
It does not show trakt new episodes list which is the most important to me. Having to click on 50 plus shows every time I want to watch a new episode is a hige waste of time.
Trakt works much better in kodi but everything else is much slower in kodi including on not finding some shows.
Since trakt works perfectly in kodi seems unlikely it would be a trakt problem.
Try this link: it is self explanatory.
Download it and it will be added to your addons.
BTW @Dak7385 this isnāt aimed at you Iām just replying to the thread in general. But you know that.
I have used Stremio for several years. It does seem a tad more difficult for some to use, but eventually with the desire and learning they can get it. On My Stremio I have a library of series I watch on a regular basis. Each one is listed with their āposterā. I know when my shows are released each week but if I donāt, I simply go to my library and any new episodes that I havenāt watched but are avaialble for me to do so are shown on the poster with a number in the top right. So if Iāve been away, I open my library, scroll through my posters, and see one of my series has say a 2 on it. That means I have 2 episodes of that series I can watch. After watching an episode it gets marked with a check mark. Future yet to be released episodes are marked with an egg timer overlay. Hovering over a future episode brings up a brief description as well as itās release date. I donāt have trakt and never have found I needed it. Again itās all about what you want or like and how you use your apps. I donāt find it productive to decry perfectly good apps because you donāt like them. Just use what makes you happy and Iāll do the same if you donāt mind.
Hi Miki. I know uou said it wasnt aimed at me.
Butā¦i donāt recall decrying apps. Or, have i misunderstood?
Lol. You never have decried anything @Dak7385 . Youāre always a positive influence. I think you can figure out whom that was aimed at. I do find it funny that certain functions in Kodi are expected to perform the same way in an entirely different app.
Hi Mikiā¦I probably had too much coffee this morningā:rofl:![]()
All good.
I still believe that these issues are "āuserā issues, and as you say, if it works in kodiā¦go figure.
Yeah not sure how Trakt works in Stremio but it works great with KODI
It works fine with Stremio/ syncler/ weyd.
But it has to be set up properly ![]()
Yes it works great in kodi but not nearly as well in stremio.
Its not the fault of stremio or trakt but the 3rd party addon.
It is not the fault of the add on. And the reason there are no numbers shown, is because you are using a different version of the app. The numbers appear in the Android TV version.
The kinhank is an android tv box. How do i get the stremio version that works with this? Stremio about says stremio version 1.6.7.
The addon says it gets watchlist from trakt. It does not get the next episode list.
Stremio.com downiads Androud TV 1.6.7. Download the first one on the list.
If you already have it, may i respectfully suggest you uninstall it from your Android box and start again.
Use this link that i sent you previously;
https://www.reddit.com/r/StremioAddons/s/eyMSMUZldk
Then add this one.
And despite your statement that it doesnt work, it works fine on my phone,my set top box and my mac.
You will also need to configure this link:
Just click on the link and follow the guide i sent you:
Thanks. I will definately try all your suggestions.
Please do. I hope it works for you.
Take your time and go step by step in setting it up.
When you add Trakt add on, make sure you choose the latest version. Sometimes the add on will show two versions. Select the latest version.
Install: Trakt up next from
Install: Trakt Tv
Install: Trakt integration
And finally: Authorise Trakt scrobbling
Pm sent
You need to configure trakt on your computer in the Stremio web page. When you add it there, thereās a pop up where you can customise it and use the Trakt app on any device to add to watchlist, collection or custom lists.
I watched my first few shows on Stremio last night, āSay Nothingā. I need to figure out the Trakt integration and how it relates to āLibraryā. I kept getting an error when I tried to go to the Trakt Collection and Watchlist tabs even though I synched all the Trakt content and it dumped into the library.
Do I need to ādeleteā movies Iāve watched out of the library? They donāt seem to go away after you watch them like they fall off the watchlist in Kodi.
