STREMIO....questions answered *readme*
That’s right I forgot about that. Yeah the QR codes no problem, as soon as you put your phone up there it gives you code four numbers I believe or four letters and these key that into your account on your computer.
Try turning off your VPN if you have one, and log off and re-log on stremio on your PC
https://link.stremio.com/
tried that no difference
never see this
Sorry. Haven’t a clue what you’re saying.
i never see this link page ( as per your url u posted}
all works well on my computer but but not on fire stick
Sorry but I think you misunderstand. You won’t see that link. Once you scan the QR Code you will get a 4 character code. Then while on the same network you open a browser, enter the URL I show, then when the page opens you enter the 4 Character code where it shows, and Stremio will then be linked.
i get no 4 character code at all
Did you scan the QR code with your phone? That’s how you get the 4 character code.
Make sure you have a account with stremio.
Then put that URL onto your computer to open up the link that Miki just showed you.
Make sure you have streamio download it on your fire stick open it up and should come up with a QR code scan it with your phone it should give you four characters either four letters four numbers are mixed probably all uppercase.
Transcribe those four characters onto the link hit enter and you should be connected.
Make sure you have a app on your phone that can read a QR code. Assumption is the mother of all evil.
Did you ever get St r e m i o to work?
All set they moved over to KODI :rofl:
Stremio Tech Update #31 – Stremio Android TV Updated – The Stremio Blog
^ Stremio ToS: third party ads
kodi + cloud caching
I don’t trust stremio because their ToS allows 3rd party ads
I haven’t seen one ad since an update many months ago. I turn Stremio on, go to my library, watch what I want. Stremio is my Fave by a long shot.
I have Stremio working fine on one Onn box and I recently fired up another Onn box and installed Stremio but when I try to stream any show the are no streams available. I can’t figure out what is wrong. Any thoughts?
welcome
I am sorry I don’t use the ONNs so I haven’t any idea why this is happening. Hopefully some insiders will see this and chime in.
Anyone getting on stremio
