⁉️ Stremio Fixes - Most Common Problems with Solutions
I’m assuming you are using Torbox? Torbox is down right now.
Stremio isn’t working for me on either of my setups. I’ve tried moving around the different Stremio addons with no luck at all. I tried Duck Streams on TV #1 and for some reason it doesn’t show up now on TV #2. I admit the others Comet etc. seem linked to Tor Box.
Stremio is working for me without any issues. DuckStreams providing tons of playable links as always.
Torbox back online now.
You were probably playing links using PM or RD as Torbox was definitely down.
Oh ya I never said torbox wasn’t down. I said Stremio is still working for me as is DuckStreams. Torbox API was down, not usenet though.
Hi, I am having issues with unsupported files. In the stremio app.
Can anyone help me?
Hi Troy,
I have TorBox and Premiumize. I tried following your BootStrapper video several times to no avail “Sync Failed” When I added TorBox, I hit the + sign and added Premiumize also. It did populate all different sites but would not sync.
I even tried it with just TorBox and it still failed to sync. Any ideas, I do have Nord VPN active while doing all this. Thanks for your sage assistance, I really appreciate it.
Hi Troy and friends,
First, Thank you for all of your hard work, keeping us informed and very helpful videos! You were my first- jailbreak.:smirking_face: I am/was a Firestick/Cinema simple kinda person until recently. I converted to the Onn 4K, Premiumize, Vanish IP, Stremio - yes I watched all the videos and followed the instructions to the best of my knowledge using Bootstrapper etc. - also read comments etc. I was successful with install but, there was a lot of buffering. I later added Torbox successfully. However, I am still experiencing a lot of buffering. I tried using a different player and turning my VPN on and off, but to no avail. Can anyone assist in this matter? I am not tech savvy, so please be gentle. Thanks! :blush:
Search Is Your Friend...!
Example :down_arrow:
I install streaming but it will not play any of the shows
Watch the vid and Tutorial from Troy that I posted above.
Has anyone ran into the failed to fethc error in stremio and been able to fix it?
When are you seeing this? How are you triggering this behaviour? What device? What addon. Is this on a series or movie? If a series is this occurring the day the episode is aired? Lots of questions to help us narrow the problem down. Please PM me. Do not name any Copyrighted movie or show.
On my stremio, I am now getting the message “File was removed from debris services due to copyright infringement” or “provider is currently unavailable” when I am trying to watch tv shows. Is this a known issue, and if so is there a fix for it? I am using a Firestick 4k Max.
Nothing you can do about copyright infringement take downs. It happens. As for the second one I’ve never seen that one.
This is happening more and more now. Hope its not a sign of doom to come.
I truly hope not. I have been watching a particular series with no problem, then bamm these messages started popping up. I was getting less add-on streams available as well. Same with streaming me other shows. But Kodi was also showing no streams available. The outlook is not looking bright. I wonder if these providers found a way to kill the cord cutting issues.
I use Stremio with Premiumize.me on Torrentio and Torbox. Lately I have been having problems with the audio not syncing with the video. Any ideas or fixes? Thanks, Fujimo75
