Using Samsung Tablet A9+ with Android 15 OS
Stremio v 1.8.1 worked, but not well. So I uninstalled, then reinstalled from Stremio website (Stremio - Freedom to Stream) v2.1.4 for Mobile devices.
Much to my surprise and delight, the Addon section had apps like Comet, AIOStreams, Media Fusion and much much more. All you had to was hit the gear icon to Configure and then innstall! Couldn’t be easier.
Once configured on my tablet, it was all saved to the cloud so that when I opened my ONN Pro it was good to go.
And the UI was delightfull on my tablet.
If you don’t have an Android tablet, borrow one and log into Stremio…It’s so easy
I never actually have used it to watch VOD, I use it on my Pixel Tab strictly for configuration of add-ons. ![]()
I use stremio-web for configuration
I do that as well and click the add addon and then use the json. Options, options, options. ![]()
I cannot figure out how to create a post. Can you help me
i may be wrong but ….
Forum Rules & Regulations
You must be a TROYPOINT Patron or Founding Member to create new Topics and reply to topics in all categories
On my other TV, stremio works fine…This one just started recently and have been having trouble. All the servers on either a movie or series do not open Stremio. I uninstalled. I restarted. Still not working.
What device are you having trouble with? I’m not fully understanding what you are saying. The movie doesn’t open Stremio, you open Stremio then search for your movie and once found, click on it and then Stremio will scrape, supply sources then you choose a source to play.
Would there be an explanation why stremio/firestick on one tv does not seem to work properly; but on another stremio/firestick tv (on the same wifi/internet) works fine?
it is only showing me options to pay for the movie its not scrapping
Go into your addons and uninstall watchub. Have a buffer free day.
I am having the same issue. In the Great room my Stremio is working great. In my bedroom, even with the 1.9.6 update, it is terrible. It is not bringing up anything. Could someone help please?
